Damage Estimate?
RAYJAY
UNION DALE PA
Tail light cover, 3rd party, chinese or 3d shop, about 20$. Paint quart 60$ (with fast activator & reducer). Dentless repair, 100$. Plus an hour to paint.
your not dealing with are USA model parts or our paint here ....... the tail lights are led here and have sensors in them and most of our paints are base coat clear coat
GreyAreaRanger
Houston
2019 Ford Ranger XLT
Surgical Nurse
This was about $3500 to repair after some idiot tried to go straight in a turn only lane while I was in the optional left turn lane turning (yes I signaled and everything) last November. If yours isn’t totaled, it would be at least 15k I am guessing.
RAYJAY
UNION DALE PA
KNI
Finland
Ranger Raptor 2021
RAYJAY
UNION DALE PA
Was just a quick example. They most likely have the same assembly or if they don't they can make you one.
Let's try with some effort:
For the Ali part you need to swap the sensor from the old one though. 200$ with the sensor.
BTW: Here in Finland they are discussing about banning thse chinese online shops, since about 1/3rd of the people have switched to use them and are bypassing the 10 price hike on the counter.
but here in Pa we hsve yearly inspections if lens does not have the dot stamp on it you will fail so many rules and reg here in the states .....
KNI
Finland
Ranger Raptor 2021
No.
(e) Other Required Lamps
- A vehicle specified under this subchapter shall have at least one red stop lamp on each side of rear of vehicle, which shall be illuminated immediately upon application of the service brake.
(f) Illumination, Except Headlamps, Fog Lamps, and Auxiliary Driving Lamps - A vehicle speci fied under this subchapter shall be equipped with parking lamps, stop lamps, tail lamps, turn signal lamps and hazard warning lamps designed for that specific function, which under normal atmospheric con ditions shall be capable of being seen and distinguished during nighttime operation at a distance of 500 feet. See 75 Pa.C.S. §4303(b)—(d).
(1) Stop lamps, turn signals and hazard warning lamps shall be visible at dis tance of 100 feet during normal sunlight.
(2) Rear lamps shall be lighted whenever head lamps, fog lamps or auxiliary driving lamps are in operation.
(3) A vehicle specified under this subchapter shall be equipped with hazard warning lamps unless the lamps were not in cluded as original equipment. Subchapter E - Passenger Cars and Light Trucks Vehicle Equipment and Inspection Regulations • PUB 45 30
(4) The turn signals shall have a frequency of flash between 60-120 flashes per minute.
(g) Condition and Position of Lamps - Lamps shall be properly fastened; direct light properly; be of a color not contrary to Tables II-IV and not be so obstructed by a screen, bar, auxiliary equipment or a device as to obscure, change the color of or obstruct beam.
cosmos
GA
2020 Ranger XLT
Thanks all, this is helpful. My goal was with this post was to get an idea for what I should plan for. This has been my daily, which ironically means I put very little thought into the ins-and-outs of it.
Poking around and it doesn't look good...I don't see the door frame/surround as even an option, the only part I can find that include the damaged component is the entire cab assembly for $9,900. I'm not going to allow them to attempt to pound-and-bondo the current one unless they can get a Ford PE to send me a stamped drawing stating that Ford guarantees complete original crash worthiness. Oh, and the inner fender rail isn't even available anymore. Mine is damaged beyond reasonable repair because the cross brace piece punched a hole clean through it.
Anyways, I'll post an update with the repair estimates.
RAYJAY
UNION DALE PA
I may very well be totaled. Modern vehicles, even body on frame like our Rangers, have crush zones, built into the design. They are there so the vehicle give itself up to protect the occupants. They are the reason you are still with us. They deflect the forces of the Collision away and around the cab. Once damages they are all but impossible to fix.
KNI
Finland
Ranger Raptor 2021
Dereku
Chicagoland Area
This is why we all long for vehicles from the past. We dont want to be safe, but at least our truck will live to see another day.
JimG_AZ
Phoenix, AZ
2021 Ranger XLT FX4
Let us know how this turns out. I say there is no way that Ford will guarantee the body shops work when it comes to crash worthiness. You may be in for a fight. One other thing to look at will be diminished value due to this accident.
rang19ca
Chuck
Carpinteria Ca
Retired Diesel Mechanic
I think you are probably looking at a total. Be sure to get as much as you can on the settlement so you can get another vehicle, whatever it may be.
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
Yes interesting that, a number of Chinese makers sell mid size utes over here now, but the cheap arse local importers often don't keep good local stocks of parts. One guy on a Chinese truck channel here cracked his diesel filter housing, which to be honest wasn't in the best of locations on the chassis rail under the truck, vulnerable to stones etc. But the local distributor quoted some astronomical price, and a wait of weeks to months to get one in stock. He managed to find the EXACT same filter on Ali Express in the exact same packing, which landed at his door 5 days later for the princely sum of $50.00 Aud including freight. He said it looked identical to the the damaged one he took out and filmed the replacement process on his channel. So I have little sympathy for some of these guys when they complain about competition.
