Check 4x4
John Jenkins
Pennsylvania
19 Ranger Larait 4x4 Super Cab
This has happened twice in as many days, only once and if I pull over and shut truck off and restart all’s good! Truck has 4700 miles on it and only been in 4wd twice back in winter! Anyone else have this pop up?
MichMan
Michigan USA
2019 Ranger XLT 4x4 2010 Ford Explorer
Any update on what you did or what a dealer found with this warning? I had my 2019 do the same thing today.
Marlin Mike
Upper Peninsula
2021 Ranger XL 4x4
My 2021 just did this. I turned the engine off, restarted it, and the light went off. If it does it again this Rangder will be down the road. 7794 miles on it,
103
Dustin
2019 Ranger XLT Sport 4x4
So you'll sell your truck because of a warning that you don't even know the reason for?
Marlin Mike
Upper Peninsula
2021 Ranger XL 4x4
Yep. I'm 59 and I don't have the time or patience to deal with running it back and forth to the stealership. I paid good money for it just like everyone else did and I expect it to run properly without a bunch of bullshit. Thats why I hate all this eletronic garbage.
Langwilliams
Langley
Lorain, Ohio
The electrics are so involved in these trucks it's probably a fault code that was triggered by a fluke. Once cleared it won't come back. The dealer can tell by the code if it's an indication of a hardware problem.
VegasRanger
Las Vegas
2021 STX Crew Cab 4x4
Damper Salesman
So you going back to a 1980's car then if you get rid of your Ranger? With roll up windows I presume too? Just in case, you know in case those go out too.
VAMike
2019 Ranger Lariat SuperCab
Ah, the good ol' days, when you could buy a ton of American steel and be sure it would run forever because there were no fancy electronics. Or at least it would run until you got out of the dealer's lot. Unless it was built on Monday or Friday, then you're on your own. But that's ok, because at least there's no electronics.
Seriously, though, there's a certain amount of shit that happens these days that might need to go back to the dealer for early failure work (a lot of times for really stupid shit like "connector not fully seated"). But after the first year, the odds that any random car will make it 20 years in good running condition without major work are insanely higher than they were 40 years ago.
slowmachine
New Hampshire
The computerization of everything is certainly a double-edged sword. On one hand, things fail a a minuscule rate compared to the analog days. On the other hand, failures can rarely by resolved by owners. Pick your poison. I don’t miss the constant fiddling with everything, but I do miss understanding how it all works.
Tony Robyn
Joplin, MO
2019 Ford Ranger Lariat Sport
City Administrator
My 19 did this today. Happened on a long hill shifting from 10th to 9th. Turned off and back on and it cleared.
kendive
Ken
23 Ranger Lariat Tech Pkg Tremor
Have you tried to put in 4WD? and if so what happens?
Motorpsychology
Prescott, WI
Vagabond
aluminum heads & arn blocks...
Motorpsychology
Prescott, WI
Vagabond
It might not be disengaging from 4H fully Try unlocking the hubs the old school way:
  • Put it 4H, drive straight for ~60ft = 8-10 revolutions of the wheels (this can be done on dry pavement if the wheels are kept straight).
  • Stop, shift to Neutral and back into 2H
  • Back up ~60 ft. Hubs should now be fully unlocked.
There may be some other problem with a sensor in the transfer case
