Center Armrest Console Storage Tray
rangerdanger
rangerdanger
SF Bay Area
I bought this tray from AliExpress and got it to work with some minor snipping in the front corners to allow the posts that stick down from the console lid to slide into place.
Nice! Photos of where to snip would be appreciated.
DHare
Missouri
DHare
Missouri
Thanks. Maybe some electrical tape for the cut edges might soften them up.
Or just some fancier cutting! I just quickly did it on a small jig saw. You can't see it once in place.
rangerdanger
rangerdanger
SF Bay Area
Can you explain how the cutting helps? I finally got my Ranger and the console tray fits without trimming, however I can’t close the lid!
DHare
Missouri
Take a look at the underside of the console lid. You can't close it because of the two pegs that hang down from the front of the lid and hit the tray. Trimming off near the front corners lets the pegs clear the tray.
Monty
Prattville, Alabama
Honda
Just ordered mine since I'm 28 days away from est. delivery. Mod's will be done with a Dremel tool
rangerdanger
rangerdanger
SF Bay Area
Thanks!
FLEngineer
Orlando,FL
2019 Ford Ranger Lariat SCrew
Reviving this thread... I just received the same tray from ebay and the corners were also chipped. Appears to be a relatively low grade plastic. That said, I'm going to glue the corners back and see how how much mileage I get out of it.
Murphie
Lindale TX
2019 Ranger Lariat 4X2, 2023 Hyundai Santa Fe
Financial Auditor - Retired
Rp930
Denver
You will have to notch the front corners which is easy to do. I’ve had it for a while now. Works great.
HenryMac
Mech. Engineer - Retired
If you have seen the "storage tray" that comes with the 2019 Ford Ranger, you'll realize pretty quickly how useless it is.
Useless? Meh... Opinions Vary. It's perfect for a 10mm Craftsman combination wrench. You'll need one to disconnect the negative battery cable when the computer goes bonkers.
IdahoRanger
Idaho
2019 Lariat SuperCrew FX4
RETIRED
