Buzzing Sound in Engine
RangerJoe
Luke
St. Louis
2019 Ford Ranger XLT
I just bought a 2019 XLT and I've been noticing a consistent buzz coming from, what sounds like, the engine. I notice it most while sitting idle in my garage, and then becomes less noticeable when I start driving and outside noise enters the cab. It gets louder as the RPM climbs. Does anyone else experience this?
I've read a few forum discussions related to this. They state that this is part of the design of a high pressure fuel pump or direct injection pump.
Hi Joe,
Likely the boost control rod on the turbo....
Porpoise Hork
Bret
Houston
IT
Mine does this and has done it since I got it. It makes the noise when I first start out down the street in the morning. It stops by the time I pull out of the neighborhood. So I hadn't given it much thought.
RangerJoe
Luke
St. Louis
Hi Joe,
Thanks for the reply, Phil. Is this part of standard operations or something that I should look more into?
Hi Joe,
Pretty much SOP..... You can mitigate it somewhat with the Lariat Engine Cover used in 2019 into early 2020.
RangerJoe
Luke
St. Louis
Is it in fact a buzzing sound or a ticking sound? because if it's the latter it's the fuel injectors on this motor which I hate the ticking noise it makes because quite frankly it makes the motor sound cheap if that makes any sense.
"Ticking" might be a better adjective. The article that JTDay posted above provides a pretty good summary of what it could be. Seems to be a common symptom of the fuel pump or direct injector design. There looks to be some fixes to reduce the sound by buying a lariat cover or using warranty to have Ford dealer replace oil pump with a more rigid replacement.
JTDay
Josh
Mazdaspeed3, M3
EHS
I don't believe the oil pump thing applies to the petrol ranger. These engines are just noisy. Take it in if you think it's something other than the fuel system.
Im betting its the HPFI hes hearing.
Hi Jack,
I think the HPFI sounds more like a sewing maching and I am getting the idea of a high frequency rattle of some sort.... Either way....nothing to which worry.
OFC Ranger
Jack
ZR2
Hi Jack,
HPFI reminds me of the old toy cars that you pulled backwards to wind, then let them go.
