Boost Pressure
Zetterbeard
Zach
2020 FORD RANGER XLT 4X4
I don't know how many folks have taken the time to install a boost gauge on their Ranger. Those who have, I'd like some comments from.
I'm seeing max boost at about 22 psi (I have the Ford Performance tune), but typically at lower ambient temperatures—say between 50° to about 75° or so. My boost drops about 2 psi as the RPM approaches redline, which I expect is normal. It also goes down at higher ambients, which is also normal.
I've read that the normal boost range is 17 to 18 pounds, but I didn't install my gauge until after the software upgrade.
By the way, this is the kit I used: (https://cp-e.com/shop/product/ford-ecoboost-2-3l-turbo-maptap/)
As I said before, it is difficult to get the connections made due to the location of the "nipple" on the intake manifold. That part took me about 10 minutes, and about 3 minor cuts! The hard part was fishing the tubing down through the heater ducting. I had to take out the top-of-dash tray, after which it went the first time. I mounted my gauge in the tray.
If you use nylon 1/4" OD tubing, and a "PLASTIC" wire fish tape (available from Home Disappointment), fish the tubing above and to the left the hood release cable as seen from the inside of the cabin. With a little effort, you can then pull the tubing by simply pushing it over the ferrel on the fish tape, and pull from the engine side. Took me about 20 minutes total.
Here are the best photos I can take. Space is at a premium, and without some sort of "snorkel" camera, this is about as good as it gets.
The blue nylon tube is the pressure line.
There are two connections to the intake manifold. The front one (in this case) is the MAP connection. The other is much too big for the "kit".
The third photo is shows the "kit" connections.
From here, you're sort of on your own. That said, it isn't rocket science.
Having some trouble fishing my tube from the dash tray down to the driver's side area you described. Any advice on where to fish this thing down?
Apples
Apples
Alan
Roswell, NM
2019 Ranger XLT
I had trouble too, so don't feel alone.
If you route the tubing just under the lip on the left, then up and over the air vent, you should be okay. It took me about 4 tried to get it done. A little tight to say the least.
GTGallop
Greg
Anthem, AZ
www.qrz.com
Program Manager
Living in Arizona, every time I see y'all using something that covers an air vent (gauges, phone holders, Kleenex dispensers, etc) I think YOU DUMBASS! But then I realize that everywhere else it probably isn't as critical. Still..... I have to wonder. Why don't I see any A-Pillar Gauge Pods on Rangers yet?
Probably has something to do with all the crap, airbag and such, stuffed back there.
Apples
Apples
Alan
Roswell, NM
2019 Ranger XLT
I do realize that finding room for extra gauges is difficult task at best. Staying out of the airbag deployment zones, is also difficult. The latter is why I finally decided not to use the A pillar.
And speaking of which... I don't use the Programming module for the same reason. It mounts on a suction cup mount, and the last thing I want to happen is, having it face planted!
ISUACE
Cody
2019 Ford Ranger Lariat
HN Customs in Australia is currently making them. They already have them for RH drive Rangers. They'd probably expedite some orders if you ask. You can look them up on fb or instagram and I got a response on fb in less than a day.
ISUACE
Cody
IMO, I like the vent pod as it still functions. But the dash tray I also considered. I was also leery about tearing into the A-Pillar. I'm sure many other vehicles have but its just something else to work around.
Zetterbeard
Zach
It looks like a few of you are using 1/4" tubing for you gauges (same blue tubing I found at Ace). The kit came with 1/8" stiff tubing and there is some 1/8" inch at Ace that says it is rated up to 55psi. Any info on tubing choice?
Apples
Apples
Alan
Roswell, NM
2019 Ranger XLT
The nylon, 1/4 inch tubing, using the correct fittings, is rated at 80 psi. This exact tubing is used in reverse osmoses units, and like most plumbing supplies, the ratings are 80, 120, and 240. Any material W/O markings are typically 80 psi.
Eskram
FL
2022 F-150 Lariat 502a Powerboost Hybrid
ISUACE
Cody
Zetterbeard
Zach
