Biggest tires on leveled Ranger
Atrin1
Dallas
2020 Ranger Lariat
Hello everyone.
I have the bilstein 5100's all around and set the front to 1.8 lift to level it out.
I"m due for new tires. Whats the biggest tires i can go without any other mods to the suspension on the stock Lariat 18's?
TIA
RuggedRanger
A.
There's some older but still valid and really good threads on here that go into a lot of depth with charts and breaking down what combinations work.
The tl;dr is you can fit 33" in there with spacers on stock wheels or get new wheels with less offset. You'll also need to remove the crash bars in the front & back of the tire, or replace them with low clearance ones.
I think you can fit 35" with a 6" suspension lift, but that's a whole other ordeal. 35" will also fit with the Baja pro-runner suspension system if using their fenders. Otherwise, you're at 33" and below.
I have Toyo AT-III 33" tires on 17" Icon wheels with zero offset, low clearance crash bars and Fox 2.5 suspension & Icon rear leafs set to leveled height.
Zero rub or issues with this setup, and was the same situation when I had Eibach 2.0 shocks and OME rear leafs.
Hello everyone.
TIA
Thats a good question for AI (GROK)...hopefully, it'll do a quick job distilling all 10 million posts on this subject just at Ranger5G...
Bob902
St. Louis
RETIRED!!!!
Hello everyone.
TIA
I put 255/70/18 on mine. Fit perfectly
TxOTRRanger
Clay
Elwood, Texas
https://www.ranger5g.com/forum/threads/biggest-tire-on-stock-18”-rims.20192/
Here is someone with 18" wheels.
The search function here is pretty good, you just have to dedicate the time to sorting through it all.
I agree with the All Knowing Club, Grand Poobah... and my other All Knowing Club compadre! 😎🤘
YaBoiNewton
Automotive Engineer
You could avoid doing all of that AND fit over 33" tires if you keep the tire width to 255
YaBoiNewton
Automotive Engineer
Will this work under compression with stock wheel offset?
Yup! I'm running 255/80r17 tires on the stock wheel, no spacers and I do not rub anywhere, even off road. They measure about 33.25". Maybe there would be some contact with the sway bar disconnected, but as it stands right now I don't hit anything through the wheel travel. Did plenty off roading on this setup, including some good articulation, and see no evidence of rub.
This width is admittedly difficult to find with 18" wheels.
RuggedRanger
A.
Nice! That's awesome. I'm a fan of pizza cutters. :D
Any change in turning radius? I think that I sacrificed a little with my setup.
I started with the stock 17" wheels, got tires and then got new wheels with some bead grip after smashing one of my stock wheels apart on some rocks while aired down and way TF off grid alone in the mountains. If I hadn't gone this route, then I would have absolutely gotten some skinnies.
YaBoiNewton
Automotive Engineer
Not really any noticeable changes. TBH I think any difference is muted by the fact that the tires are E-load and can be rough as shit on the road. I exaggerate, the ride is plenty comfortable, but it's a huge change from the SL tires I replaced.
Another drawback on this tire is that they can be difficult to mount without a very strong compressor. This may be specific to the Duratrac RTs, but the mobile tire installer struggled to mount the rear tires due to the width and stiffness. He got the front tires on fine, but had to leave my truck on jack stands and take the back wheels to the shop and use their big compressor. I would be absolutely cooked if I aired down out in the woods and popped a bead. 😁
I would definitely get a skinnier bead locking wheel if I was looking to air down frequently. Not off roading much lately so for now I just bump along on rock hard tires...
rbern
Rich
2021 ranger stx 4x4
Factory
Just put on falcon rubitrek 265/65 18 on stock 18-in wheels was going to go 70 series Glad I didn't in reverse driver barely rubs a front crash bar I'm leveled at 2 and 1/2 in 1-in blocks in the back and one and a half inch wheel spacers
Atrin1
Dallas
2020 Ranger Lariat
can you post pics of your truck? Those are the tires I’ve been thinking about getting too. How do you like them?
rbern
Rich
2021 ranger stx 4x4
Factory
I can but I'm at work till 6 pm. I do like them only got 1500 or so miles on them. Alot more road noise than original hankooks but not bad .
Atrin1
Dallas
2020 Ranger Lariat
No rush appreciate you!
