Alignment on leveled Ranger
For a level ranger - non tremor - you use a combination of -Tremor and Non Tremor Specs as there is not a published spec for Leveled stock -
Let me think for a bit - it’s been quite a few years since I aligned professionally
Essentially you just use the factory specifications whether the vehicle is leveled or lifted. One thing to consider especially with a leveled truck and some lifted trucks if you go to High is that you may need a new upper control arm in order to get into Factory specifications. Also be aware that with my 2019 Ranger that I had with a lift from Old Man EMU I was able to get the vehicle back into the factory specifications with the OEM control arms without issues.
