Best portable Air Compressor?
JesseS
Jesse
NorCal (Roseville)
I have a superflow for my RV that's to small for the 19.5" tires, so will move that to the truck, and get a new one for the RV, which one is best, the Superflow MV-90, or the Smittybuilt 2781?. Anyone with either chime in, and does the Superflow have a auto cut off? I have read conflicting statements on this.
JesseS
JesseS
Jesse
NorCal (Roseville)
There's a lot of good portable ones out there now. When I was researching them I went with my Jeep friends advise and went with a Viair 88p. I can air up my 32's without having to wait for the compressor to cool down, I think the duty cycle is 25 minutes. It's a great middle of the road compressor.
https://www.amazon.com/gp/product/B005ASY23I/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&th=1
I looked at that one, at 1.5 CFM it would be pretty slow on large tires. The Smittybuilt is 5.65 CFM, much faster, and cost 3 times as much although cost isn't much of a factor.
My Air Compressor is driven off my CAT diesel in the RV....150 psi availalbe in high volume... I carry 100 ft of air hose to reach other folks that might need help... My tires are quite a bit larger too so takes a few minutes to fill them....
Megawatt
Sin city
Unicycle.
I make electricity
…. The Smittybuilt is 5.65 CFM, much faster, and cost 3 times as much although cost isn't much of a factor.
Ok mr money bags :) If cost isn’t much of a factor step up to ARB single or dual air compressor. You will not be concerned with “faster”, it will simply make the smittybuilt look like shittybuilt.
Viair has many models/ sizes to choose from. Pick the best suited one for your purpose. No way would I even consider smittybuilt over viair.
Sorry still a little brain fog going on and forgot where you said 19.5" tires. In this description it says the Smittybilt 2781 has Auto-thermal cutoff switch - protects motor against damage.
Here's a link for the different Viair in case you want to go that route. I've had great luck with mine along with many of my friends. Smittybilt seems to be hit/miss from what I've seen.
https://www.amazon.com/s?k=viair+300p&crid=3C2VMHX0YBYXX&sprefix=viair,aps,232&ref=nb_sb_ss_ts-doa-p_5_5
GTGallop
Greg
Anthem, AZ
www.qrz.com
Program Manager
2020FRL
Alan
Grand Junction, Colorado
2020 Ford Ranger Lariat, 2014 Harley Tri Glide
I use the bolt battery charger with light and compressor. I've used it to fill the truck tires and the trike rear tires. As a benny, no power needed. It supplies it's own. Also, it can jump start a big truck. Used it a couple weeks ago to jumpstart my neighbors 2005 F350 diesel. He was spectacle, but, it did the trick.
Bolt w:Compressor.webp
FXranger4
Shawn
San Diego, CA and Lake Ariel, PA
21' Ranger Lariat FX4 Triumph Tiger 900 GT Pro
Moving Electrons Around
RangerAl87
al
Westchester,NY
2020 ford ranger XLT
Tech
https://www.amazon.com/GSPSCN-Inflator-Cylinders-Portable-Compressor/dp/B077N9PXV3
This is what I got. Is it the best? No!
Is it pretty damn good for less than $60? You bet your sweet ass it is!
Airs up so fast it takes all of the excuses away for not airing down on the trail.
I purchased the same one over a year ago and used it about 25 times and it shit the bed as of three weeks ago. Just replaced it with the smitty , used it once and I was impressed. Not a fan of the Japanese fittings . But I've seen people mod them with standard fittings and a pressure switch
