Bed cover rec?
19silversport
Aubrey
New Jersey
2019 ranger
Looking for recommendations for a bed cover. Would like to make it more functional with keeping some items out of the elements while driving. Searched on the forum and it sounds like truxedo leaks often. I looked at the ford version
Ranger 2019-2023 Advantage Hard Folding Cover Bed Cover for 5.0 Bed | Accessories.Ford.com
and roughcontry
Hard Tri-Fold Flip Up Bed Cover | Ford Ranger 2WD/4WD (19-24) | Rough Country
that seem very similar and RC is $500 less.
I havent seen any rangers around me with covers so curious what you recommend. I vaugly remember when I purchased the ranger back in 18 bedcovers werent an option if you had a spray in liner -- not sure if its a ford ordering thing? or spray in liners arent compatible somehow?
Appreciate the help!
RedDakooter05
Illinois
2024 Nissan Frontier S 4x4
Gator etx soft roll up.
Gator ETX Soft Roll Up Truck Bed Tonneau Cover | 133105 | Fits 2019 - 2023 Ford Ranger 5' 1" Bed (61'') https://a.co/d/fHtFz7O
I like the low profile nature of it. Seems secure enough but leaks a little at the tailgate due to th gaps. Front of my bed is always driy.
19silversport
Aubrey
New Jersey
2019 ranger
wow thats pretty slick and a great price!
AzureRanger
2006 Jeep TJ
I have the Bak Revolver X4s hard roll up. I like it a lot. Only leaking I've seen is a tiny bit at the tailgate corners. Only downside is that it has to be all the way open or all the way closed. Can't open part way while moving. I had a retractable cover on my F150....that was my favorite, but wouldn't get one for the Ranger.....the canister takes up too much space.
joeduran3
Green Valley, AZ
2020 Ranger, 2013 Subaru Outback
and roughcontry
I have the BakFlip MX4 and I can recommend it. It's not cheap, but it looks good and doesn't leak. The only water you're likely to see is from the tailgate seals (lack of sealing). I also have the spray-in bed liner, so it's compatible.
MKC1911
2021 Ranger Tremor
I was looking for something to keep the leaves & tree stuff out of the bed and went with the RC Tri fold soft cover. It only took about 15 minutes to install and fits great.
It might leak a little at the front corner but so far it hasn't. Truck has a drop in liner and it isn't a problem. For the price & my needs it is perfect.
Tom_C
Virginia, USA
System Admin, Retired
I have a gator soft, tri-fold. It's s struggle to get it sealed completely due to the design of the gate. It can be folded back and secured at the cab, or taken off very quickly with 2 hand tightened clamps. I took it off a year ago to carry some large stuff and haven't put it back on since I've been carrying a lot of big stuff.
https://www.ranger5g.com/forum/thre...spray-in-liner-removal-from-bolt-holes.13013/
LT Dangle
Brett
New York
21 FX4 (RIP), 21 Tremor, 20 Edge ST, Couple HD's
Trophy Husband / "Sanitation Worker" / Army Vet
@19silversport where in Jersey are you?
I've always preferred the soft roll up. never had any issues with leaking. my current 5G came with a hard tri-fold. So far, I'm not unhappy with it. works as it should.
bbeverag
Normal, IL
2022 Ranger Lariat Tremor
I have this tonneau and would also recommend it.
Glocker
Boca Raton
I have this hard-rolling cover, and the price on it is phenomenal. I bought mine back on May 25, 2020, and have had ZERO issues. That's amazing because this cover is about $850, and similar covers usually cost about $2,000!
https://a.co/d/3U8evAJ
Glocker
Boca Raton
I don't recommend this cover. I have it and it leaks like a sieve.
I don't have that exact cover, but I'm thinking the one I have is probably made in the same factory. Do you have drain hoses that extend down from the "canister" the cover rolls into? One time I realized mine was leaking really bad, and I ended up cleaning a lot of gunk out of the train tubes. I haven't had any issues since, but I have a feeling that it will take some occasional maintenance like that to keep it leak-free.
Mtnbikes
MN
Then you must have it installed wrong. Mine leaks little to none, especially if I go through the car wash.
xplorre
Various parts of California
2021 XLT FX4
I do have the drain hoses and they're installed properly, I checked recently and they're clear. My problem is leaking around the rear 1/4 or so near the tailgate. I can watch water dripping out of the track into the bed about 12-16" from the tailgate.
