Balljoint question
Dereku
Chicagoland Area
I am nearing 150k and finally started to hear some noises. Im going to do ball joints (or control arms) and tie rods. Does anyone have any experience with the correct part numbers for steel knuckles.
I found lower ball joints and control arms on rockauto. But nothing for uppers that specifically states steel. A few say aluminum but I do not want to assume the rest are for steel.
If anyone has replaced theirs and has some knowledge I would appreciate it.
No experience on my end with these, but I would at least do the checks to see what parts have failed. Might help you save before replacing what doesn't need replacement
Ok
The Mid Production (2020)- Change
Was changing the (Knuckle) from Aluminum to Steel
The Lower Contral Arm (Part Number Changed) only to differentiate a different Ball-Joint stud to match the (new steel) knuckle
The Upper Contral Arm - was unchanged
These numbers are from the Ford Parts sites.
I see Rock Auto has different numbers listed
and it appears the UCA - Part Number Changed but the Ford Parts (Cats) do not reflect it:
So looking at Rock Auto
LH: MCF-2603 / Crosses to: KB3Z-3085-B
RH: MCF-2602 / Crosses to: KB3Z-3084-B
So sometime recently they revised the UCA PN.
It comes up within the Ford sites, but however it does not confirm fitment to the Ranger, so it appears to be the lag in getting the system to update, as I have seen in the past - it takes some time.
I will note that other members have reported difficulty in pressing in ball joints and getting them to seat properly (if I recall correctly) and ended up buying the assembly anyway.
I have not had to do anything with mine yet, so cannot confirm the issues.
Forgot: Tie Rods (Outer)
Pre:
LH: KB3Z-3A130-D / MEF-521
RH: KB3Z-3A130-B / MEF-519
Post:
LH: KB3Z-3A130-E / MEF-3721
RH: KB3Z-3A130-F / MEF-684
Dereku
Dereku
Chicagoland Area
So the uppers are the same? I thought people had issues with the aftermarket upper control arms having different ball joints for the knuckles?
Dereku
Dereku
Chicagoland Area
With the miles I have it is due all new ball joints. If I am going to do one, ill do all. Could be control arm bushings getting soft too, so I would prefer to swap the whole arm. Need an alignment afterwards either way.
Probably will do tie rods for the hell of it. Everything seems solid. But it doesn’t feel as tight as it once was.
Ok,
Let me start over here -since the Ford Parts Diagrams are generating my confusion.
I should have checked my usual reference site for clarification on the other sites that still list the incorrect part numbers.
I know we have had numerous threads about the part numbers and what changed. But with Ford not updating all parts IPC's it makes it confusing on what is correct.
The below IPC's show what the others do not - the real part number changes.
Upper Control Arm:
Upper Ball Joint:
Lower Control Arm
Knuckle IPC
Knuckle PN's
Tie Rod IPC
Outer Tie Rod PN's
Dereku
Dereku
Chicagoland Area
Thanks! That makes sense for the control arms. I would assume the 6/2020 and later parts correspond to the steel knuckles.
What is still confusing is the replacement upper ball joint is for all rangers. There should be 2 different ones. But I am doing full control arms so its fine.
Thanks again
It appears the Ball Joint PN - remains the same, but the mounting angle changed to match the mating surfaces (new knuckle to new UCA)
What specific dimensions they changed - IDK.
I am thinking its the thickness of the upper ears - on the 2 knuckles - generating the changed UCA.
So quite possibly that the UCA was revised with a slightly changed (ball joint) mount point to drive it (thicker mount) closer to the new knuckle.
Meaning that the ball joint - when installed (pressed) would set slightly deeper than the OE design.
So an old (PN) UCA with a new (Knuckle) would allow slop in the mounting :question:
I am just (spit-balling) here as I have nothing to back up my theory.
The only way to really tell would be a micrometer measurement of the Knuckles and UCAs.
New vs Old PN's
Dereku
Dereku
Chicagoland Area
New vs Old PN's
Or maybe the ball joint is identical and it is the shape of the UCA that is different.
I know the lower is a different length and taper on the stud.
RangerBill
You could check with Benny at Levittown Ford with your VIN to verify what part numbers are correct.
ScarzRanger21(2.0)
Eric
Auberry, CA
Electrician
I dealt with this personally… The ball joints for steel vs aluminum knuckles are NOT the same. Make sure you know what your truck has before you order anything! Lol also if it’s lifted you’ll want something with more angle to accommodate the ball joint movement.
Dereku
Dereku
Chicagoland Area
Knuckles are for sure steel. And the front is leveled the lowest setting above stock on 5100. So no issue with the height.
