Auto Start no longer functioning.
AtillaTheHung
Zachary
Knoxville, TN
2019 Ford Ranger - 2010 Ford Ranger
Systems Administrator
While I really dislike this feature in many ways. I also dislike when things that should function, don’t function.
Truck has been parked for a while. Drove it 200 miles the other day, and then 60 miles the next day. Auto start didn’t do anything both drives.
on the dash, it says ‘Engine On Normal Opr.’ But all I see is the grey A with the circle around it.
plugged in Forscan and this is what I have.
is it as simple as a battery replacement? Relatively annoying.
t4thfavor
Chance
It won’t function for a crapload of reasons. Ac on mine will hardly ever work. I went into forscan and bumped the voltage targets on the charge controller to 85% and it seems to have helped a few of my issues. I think Ford used a very weak battery as mine will drop well below 10.9v every start. I have not seen this happen on any battery I’ve owned even in diesel vehicles requiring lots of cold cranking amps.
the target may have been 90% but I can’t recall.
LoneRNGR
Lubbock, Texas
2020 Ford Ranger XLT
Systems Engineer
The battery is low and needs to be recharged. When charging, connect the negative wire to a chassis ground, not the negative battery terminal. Otherwise the BMS will not detect the charge and the BCM will continue to prevent the auto start stop feature from operating. See video:
https://youtube.com/shorts/cJkTtvjzunI?feature=share
wanted33
Down south in Dixie
Mustang GT, Jeep Wrangler
Old used up LEO
I feel exactly the same way. I don't care for the ASS, but I want it to work as it should. Had the same problem with my Jeep, and it was the battery. Had it replaced, and it works fine now. Not that I use it mind you. :)
AtillaTheHung
AtillaTheHung
Zachary
Knoxville, TN
So you have the ability to change the levels required for it to work? What module is it in? Not that I’m going to do it, but I wouldn’t mind testing a lower level just to see if it does indeed fix my problem.
Truck starts perfectly fine manually. Hard to believe a 0.2v difference would make S/S not function.
AtillaTheHung
AtillaTheHung
Zachary
Knoxville, TN
So I could try charging it with a charger. Interesting. You’d think that the alt would charge it just fine on my trips.
t4thfavor
Chance
you have the ability to change the desired level that the alternator will keep the battery at. So it’s set at 75% from the factory which pisses off some more sensitive equipment like ham radios. So I changed mine to 90% and the ham radios are happier. They still restart every stop/start cycle, but they don’t do it while driving anymore.
It's possible the battery is bad, mine was after only 18 months. I have the Ford version of this trickle charger. There are times where I don't use my truck for several days and it keeps the battery fresh and topped off. Like John said just make sure you ground it to the body and not the negative terminal. I used the quick connect pigtail and not the clamps.
https://www.amazon.com/dp/B00CD44RQ...olid=1JZJN0W5WUIWA&psc=1&ref_=lv_ov_lig_dp_it
LoneRNGR
Lubbock, Texas
Systems Engineer
The Ranger has a variable alternator and just because the engine is running doesn’t mean that the battery is charging. The BCM and PCM control when the alternator sends charging voltage to the battery. The battery is rarely kept at a 100% charge.
Motorpsychology
Prescott, WI
Vagabond
10-4. The BMS needs to know what the new, charged up reading is.
With the chip shortage, maybe the OEMs could get back to installing $20 voltage regulators.
AtillaTheHung
AtillaTheHung
Zachary
Knoxville, TN
I guess what I’m saying is, is that the smart charging feature is incapable of bringing my battery back to where it should be at for S/S to function. And that it might be possible to rejuvenate it enough with a battery charger for it to function?
basically. The smart charging system knows the battery needs charged - shouldn’t it charge it to the required level?
LoneRNGR
Lubbock, Texas
Systems Engineer
It should, but it seems it gets out of sync every now and then. I travel on planes a lot. After a couple of months of 4-5 days parked at the airport each week, I need to charge it.
12Bravo20
Missouri
2020 Ford Ranger XLT FX4
These systems can be fickle to say the least. It could be something as simple as the battery being weak for not being driven. Or it could be that your battery is starting to go bad. Another thing that can cause issues is the intelligent battery sensor.
The ASS never did work on my 2016 Jeep Cherokee (bought used). I had the battery and charging system checked several times. It very well could have been teh IBS which on the Jeep is connected to the negative battery terminal.
I haven't delved into the Ford system much. On the Chrysler system something like the the hood switch will cause the ASS system not to work.
Hi 12B
It should be a simple test to disconnect the Intelligent battery sensor and try Autostart. That would indicate investigation into the battery/system. Comments? I am a bit out of my box on this one...
Ford Motor Co Retired
arbjosh
Josh
Denver, CO
2021 Ranger Fx4
Arborist
Does Ford switch out the battery if it's under warranty?
