Anyone have a drop in bed liner?
alazar14
Juan
San Diego
Ford Ranger (2019), Chevrolet Camaro 2002 Anniversary Edition
Hi all,
I'm supposed to get a call from the dealership soon to have the running boards and drop in bed liner installed. I have actually never seen a 2019 Ranger with the drop in liner, does anyone have one? If so, would you mind taking a picture and sharing it? I wonder how the fit is for these liners, and if they block the tie down spots.
I have read that these liners can potentially scratch the paint underneath them. Further, I read it is important to clean under the liner at least once a year to prevent rust.
Stic-o
Lake View Terrace, CA
The tie downs aren't that hard to get to. Never worried about scratching the bed, and if it was that bad you could always rhino line it.
rangerdanger
SF Bay Area
Hi all,
Photos here: https://www.ranger5g.com/forum/threads/spray-in-bedliner-with-12v-power.1234/
alazar14
Juan
San Diego
rangerdanger
SF Bay Area
Wschnitz
Will
Bellingham, WA
2019 Ford Ranger XLT FX4
Your Enemy is movement, so if you put some foam tape or spray some rubberized bedliner on top of a couple of the rails that would be best for protecting scratches from forming. But otherwise its inevitable that it will eventually wear through. Ive had it happen to my Toyota with OEM liner.
t4thfavor
Chance
Was going to comment that I had the plastic bedliner out a few weeks ago, and it was already working its way thorough the paint. That said I just got rid of a 2003 FX4 with a plastic drop in that didn't have any holes in the bed (rockers were MIA, but the bed was not rusted through).
I put some grease on it, and forgot about it.
Tinsoldieroh
Cleveland Ohio 44095
Had an'86, a '94, and an '05. Left with wife's jeep until the '19 arrives
My 2005 had a bed liner from day one, bed was still solid, had a few scratches but that's all when I sold it. The new factory bed liner has 4 inch rubber grommets that cover the holes for the tie downs. Just put a solid lift up painted to match cover on my super cab and expect both to last for twenty years.
Johnpenn
Rockwood TN
2019 Ranger Lariat FX4, 2004 Corvette, 2005 Ranger Edge
Retired Quality and EHS Manager
Mine came with the Ford drop-in. I hated the look. Got the dealer to trade it for Line-X as part of the deal and I got to keep the power outlet. I'm much happier with the LineX. The tailgate is a little tougher on the knees but I can always get the bedrug tailgate liner. later I already had the Ford rubber bed mat before I bought the truck so I just put it on top of the LineX. I had planned to LineX once the bed got scratched up too bad anyway so best of both worlds.
alazar14
Juan
San Diego
I'm thinking of putting some foam tape on top of some of the rails to keep it from scratching as someone else said. I saw a post of somebody with a Toyota Tacoma who did the same thing and it seemed to work out great. I think the individual just put foam tape on the lower rails so that the bed would sit on the tape instead of the actual bed. He also appeared to put foam tape on top of the wheel wells. Does anyone know if this might work? Would the foam tape be very difficult to remove a few years down the road / peel off paint when removed. I'm thinking about getting a spray in liner with Line X in 2-3 years, but for now I just want to use the plastic bed liner.
Thanks!
beetlespin
NJ
2019 Ford Ranger Lariat Supercrew FX4
I have the drop-in liner and love it. Had one on my 2011 F-150 3.5 Ecoboost also. Easy to clean, just spray it out with a hose.
t4thfavor
Chance
Thanks!
It doesn't go over the top of the rails, basically the top of the rails is already plastic, so they didn't cover it. foam tape would probably wear off after a while and you'd end up with the same scratches. If it's not a show truck, I wouldn't worry about it :)
idesi1
Shad
Houston - Sugar Land , TX
2019 Ford Ranger Lariat Ignot Silver with 501A + Sport package
Randy
Randy
Ranger 2019
Spray your bed man... liners are a thing of the past... Protect it, if you go to someone that does good work, they will remove the rubber grummets, the torx screws for your tailgate lid and do an exceptional job. Mine cost me $369 and a 1hr drive. I go to this one guy only everytime, superb work he does. My bed is almost 10 mil thick.. strong as hell.
I have factory drop in liner because I knew I was going to cover it with Diamondback and wanted the floor to be protected with something but easy to slide in/out cargo...spray liner have too great of friction to allow this...
