5th Gen 2019+ Ranger VIN - Decoded
FLEngineer
Orlando,FL
2019 Ford Ranger Lariat SCrew
The following information is provided in section 100-01 of the Technical Shop Manual:
The VIN is a 17-digit combination of letters and numbers. The VIN is stamped on a metal tab riveted to the instrument
panel, top upper left of the dash. The VIN is also found on the VC label. If the VIN plate requires replacement,
authorized dealers must contact their respective regional office.
1 WMI (World Manufacturer Identifier)
2 Restraint-type and GVWcode
3 Vehicle line, series, body-type code
4 Engine-type code
5 Computer-generated check digit
6 Model year code
7 Assembly plant code
8 Production sequence number
The first 3 VIN positions are the WMI (World Manufacturer Identifier).
1FD - Ford Motor Company, USA, Ranger - Chassis Cab
1FT - Ford Motor Company, USA, truck (completed vehicle)
Restraint Type
The fourth VIN position is the vehicle restraint and GVW code.
E - 6,001-7,000 lb GVW, active safety belts (all positions), driver and front passenger air bags and side impact
inflatable restraints (1st and 2nd row)
Vehicle Line, Series and Body Type
Positions 5 through 7 indicate vehicle line, series and body type.
R1A - Ranger, Super cab, RWD, Pick-up box delete
R1E - Ranger, Super cab, RWD
R1F - Ranger, Super cab, 4WD
R4E - Ranger, SuperCrew cab, RWD
R4F - Ranger, SuperCrew cab, 4WD
Engine Type
The eighth VIN position identifies the engine type, displacement and number of cylinders.
H - 2.3L,EcoBoost, 16-valve, Ti-VCT (Twin Independent Variable Cam Timing), 4-cylinder, Gasoline-fuel
Check Digit
The ninth VIN position is a government-assigned, computer-generated check digit.
0-9
Model Year
The tenth VIN position is the model year code.
K - 2019
Assembly Plant
The eleventh VIN position is the assembly plant code.
L - Michigan Assembly plant (Michigan)
Production Sequence Number
The last 6 VIN positions are a numeric code for the vehicle build sequence. This is also the vehicle serial and warranty
number. The serial number can also be found on the engine block, transmission and frame.
A00001 - A99999
Pinecrestjim
Pinecrest, FL
Good to know!
MadMartigan
NY
Ford
Interesting........my check digit (9th position)is an X. Not 0-9
j0shm1lls
Josh
SoCal, USA
www.youtube.com
2016 Focus RS, 2019 Ranger SCrew Lariat FX4 Sport
myothercarizahearse
Cleveland, Ohio
Unretired
serial number A97624 built 9/19... I didn't think they made that many last year
SOHK_Alumni
Win
Tampa
Glorified Mechanic
I've got A02851 and B12311 from 2019. B12311 was an Oct 19 build, very late for a '19.
I beileve they built 2019s thru mid November or so - I can't recall the exact date. 2019 production ended on a Friday and 2020 production began the following Monday.
rozebud
daniel
ontario canada
2019 ranger xlt fx4 CC- 2002 F250 super D 4x4
ok my trucks build sheet or window sticker shows October/19. is there any way to find out what day of the week it was built on?
There are some threads on this:
Here is (one)
Build Date from VIN Please | 2019+ Ford Ranger and Raptor Forum (5th Generation) - Ranger5G.com
Not 100% accurate as far as official documents - for mine anyways
But if you look across the top of your Window Sticker - Look for (BLEND) (Underlined) this date is also on the door sticker.
My Window & Door sticker are (1) Day off from any Ford (Official) computer date.
As I looked hard at this - Ref the TSB for Transmission the CDF Drum (Step Procedures) has a decision date (that matches my Window Sticker & Door Sticker) 08/16/2022 but Ford Computers show 08/17/2022 as the Build Date.
So, I think that when it Started - (Blend) it was 08/16/2022 and (Final - Checks) were completed 08/17/2022, so the Official (Build Date)
