35" tires with a 3" Suspension Lift?
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
Sure, here is what I chose for my Ranger. A few pics with 17×9 -12 offset before and after adding the bushwacker fender flares.
Thank You!!! That's an awesome looking Ranger!!!
Jms81661
Las Vegas, NV
2020 XLT Ranger Sport
Truck Driver
I've seen 6 in lift kits that advertised the ability to fit 35s.
Fabtech says you can fit 33s on their 3.5 inch lift that includes new crash bars. This is the lift I plan on going with.
With that said you might be able to fit 35s if you are determined enough. ;)
The RC 3 1/2" lift is the way I went. Go with the BDS intrusion bars! You won't have to cut anything.
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
I finally got my tires and wheel, but had to trimmed a lot and still rub at full lock. Do you happen to know what this plastic looking like a heat sink for on the last pic?
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
What is this plastic heat sink looking thing for? What is the purpose of it? I have 295 70R17 and it's rubbing at fullock on this material. Can I remove it?
Hi Bladimir,
It is part of the splash guard to keep the water out of the back of the headlight, Horns, electrical connectors etc. Not advisable to remove.
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
Hi Bladimir,
Hi Phil,
Thanks for the info, I will not remove them. They will definitely stay. I'll probably down size the tire to 285s which will give me another 1/2 inch or find away to increase the front lift. I have a Fox 2.0 performance and 4WP said that they set it to 2.75 inch.
Thanks again.
Stangman570
Florida Panhandle
2019 Ford Ranger 4x4 XLT Sport
Hi Phil,
Thanks again.
Not to overrule Phil, but these blocks are on the rear far from the head lights. Yes you have to remove these blocks in order to allow for larger tires. Sorry that's just the way it is. No need to step down to 285's. If you take your Ranger off road and compress or articulate in a big way for sure you will hit these blocks. I did a write up back in 2019 when I first got my Ranger. Here is a pic of mine removed. I did not cut the phelt splash guard. Phil is correct, leave this phelt in place. However, now that you cut yours and you remove the block ( in the rear on the cab side ) you must find a way to secure what you got. If not it will be flappen in the wind man, lol. Once I removed my rear blocks I just stretched the phelt back in place and secured it back in place with the mounting bolt I took out from the block. I use my Ranger heavily off road and they have never pulled out or come loose. Sorry Phil, love ya Man!!
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
Hi Stangman570,
Thanks, is there some electronics behind or inside the blocks? I can purchase a phelt and put a new one. I'm thinking about doing a Rhino lining underneath the wheel well, is this advisable? Thanks again for your help and Phil as well. If you all ever happen to roam in SoCal I'll take you all for a beer and stake.
Stangman570
Florida Panhandle
Hi Stangman570,
No electronics behind the blocks. Just 3 bolts that mount them to the lower wall. The bolts on the outer next to the fender can be a pain, just take your time with a swivel if need be and you'll be fine. Also if you zoom in on my second pic you'll see I did have to do a small amout of trimming on the very lowest spot of the fender and the bushwacker flares that protudes into the lower part of the wheel well. This helped a ton off road under flex. Not sure about the Rihno line? No problem, glad we can help.
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
Thanks for the advice, I'll try to take the plastic out. I did some shaving last night. I noticed that it will rub on the front towards the fog lights housing.
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
Hi Stangman570,
Just curious, are using your stock UCAs or have you replace it?
Thanks,
Blad
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
I finally got a chance to remove the plastic behind the front tires, and I'll have to trim the bottom of the fender flares as well, like you mentioned there is a bit of rubbing just the paint.
