( 33”+ Tires, poor mpg. ) What tune are you running on your Ranger?
Bravohook
Addame
Victor
2021 Ranger XLT FX4
Sheepdog
They’re definitely heavy, but boy are they tough
Hell yeah AND by far the best looking MT, I just cant justify getting them I live in a city now. Duratracs are almost too aggressive for me. You truck looks killer good work!!
FPP tune would do you good, not to aggressive just enough.
Rambo2020R
Rambo2020R
Coleton
2020 Ranger Fx4
Detention Officer
Well according to the Oklahoma Police! I need to calibrate my Ranger! My only ticket in 30 years! $200
I need a tune and calibration ASAP! No more driving through Oklahoma!
They can see you from 100 miles away out there on the western side ? just a big ole pan
seanellaz
Sean
Tucson, AZ
Healthcare
I’ve had these 255/85/r16 Toyo Open Country’s on for about 4 months now. I’ve clocked near 7,000 miles on them, with (2) 3,000 mile rotations. My MPG has gone from 23 to 14 in that same 4 month time span. Couple that with the small gas tank on the Ranger and I’m only getting roughly 250 miles of range instead of the near 400 I used to have. I’m also looking for more power, I’ll be stepping it up to 35s for the next set of tires and I’d like to have it dialed in beforehand. That being said, what tune are y’all running on your Ranger with oversized tires? How do you like it and what MPG improvements have you seen, if any?
I have BDS 3.5" lift kit, 2395/70 17 tires. If I drive like granny, I get about 1
Installed BDS 3.5" lift Kit,
https://www.customwheeloffset.com/s...wd?year=2020&make=Ford&model=Ranger&drive=4WD.
Injen Air Inake...https://injen.com/i-30498853-injen-pf-cold-air-intake-system-wrinkle-black-pf9071wb.html
and
Flowmaster 717909 FlowFX Cat-Back Exhaust System... https://www.holley.com/products/exhaust/exhaust_systems/flowmaster/flowfx/parts/717909. Deleted the muffler.
Knowing that when you enlarge the exhaust pipe, the gas expands, cools, and slows down, I then wrapped the exhaust stem to stern with fiberglass to keep the gas hot, and moving.
VViViD Black FiberGlass Heat Shield Exhaust 2" x 50'... https://www.amazon.com/VViViD-Fiber...haust+wrap+2+inch+x+50ft+,aps,150&sr=8-2&th=1
The wrap was pretty cheap. I figured it would not last long if left naked, so I painted it with brush on POR-15 High Temperature Paint - Aluminum ........ https://por15.com/collections/high-temperature-paint/products/high-temp?variant=39607014588583 let it sit 24 hrs then drove the truck 10 minutes to the grocery store. Paint curing stunk so bad I worried the VOC's might ignite. Let it sit till cool, then 10 min drive back home. Still some stink but less. After a few drives no more stink from paint.
I can put my hand on the pipes, no burn, right after pulling off the hiway with a trailer. Also it is notably cooler in the cab when idling in the 115degree Tucson summer heat +++++.
The painted wrap acts as an external muffler. Truck was so quiet I deleted the muffler. Still not loud unless accelerating with heavy load, pulling up hill, etc.. Quiet @ cruise.
Can't get 93 Octane in AZ, only puny 91, so not sure a tune would make much difference. When I go to Texas, where I CAN get 93 Octane gas, it REALLY makes an very noticeable difference, another level of oomph, when I squash the pedal to the floor. Of course MPG suffers anytime I do that regardless of octane.
Run Yoyo Open Country 295 /70 17 R/T tires, no rub, no scrub. I get about 18 MPG, driving like granny in town, 65mph on hiway. ZERO complaints about under power. Truck pulls like mule and runs like scalded dog. No "Tune". GAWD knows what the truck would do with a tune. Scare the crap out of me probly.
Colin Stuffmann
Colin
Los Angeles
2019 Ford Ranger XLT FX4
Is your speedometer accurate with your GPS speed readout?
I'm only running 32" tires and my true speed is about 2 mph faster than the speedo shows.
One day I'll adjust it but that'll be when I get a round tuit.
I have 33x12.50x17 and my Speedo is off compared to gps. Only off by 3mph
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
VViViD Black FiberGlass Heat Shield Exhaust 2" x 50'... https://www.amazon.com/VViViD-Fiberglass-Exhaust-Including-Stainless/dp/B07CJMGR7R/ref=sr_1_2?crid=3MPI4MJ954EDR&keywords=VViViD+FiberGlass+Heat+Shield+Exhaust+Wrap+(2+Inch+x+50ft)&qid=1672683582&sprefix=vvivid+fiberglass+heat+shield+exhaust+wrap+2+inch+x+50ft+,aps,150&sr=8-2&th=1
I would not recommend the wrap for everyone. In a wet environment, the wrap will hold moisture and will cause the exhaust to rot off.
MikeG
South Texas
Chauffeur
Everything changes MPG.
Bigger Tires
Lifts.
Levels.
Removing the front air dam.
Adding a push bar.
Adding a grill guard.
Adding light bars or round lights that air has to slam into.
Adding doo-dad attachments (wich I will self proclaim as the winner, as my truck now has the aerodynamics of of a brick sporting 4 wheels).
Understand for Ford to meet MPG estimates they have fine tuned everything down to the comical factory rake of the front nose dive.
I can get about 17.4 MPG if I grandpa the throttle and never exceed 65MPH on the highway using cruise control. Real world MPG is similar to yours, between 13.5 and 14.5 MPG
285/70/17
3" Front / 1" Rear
93 Performance Tune
300+ lbs (not including payload cargo) of permanent steel fabrications and lots of attachments that would make a wind testing engineer cry like a baby if he put it in a tunnel.
Here is a depiction of my truck and aerodynamics;
I am running same tire and lift size with calibrated speedo with same mpg results
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
Check my thread and I'm going to recommend gears. It can be done. Especially if you're going to step up to 35's.
