303 GRAPHENE NANO SPRAY COATING
Swingpure
Gary
McDougall, Ontario
2020 Ford Ranger XLT Sport
I looked at the Last Cost line of products and they look excellent and you will have an excellent result. The 303 Graphene is also an excellent product and has advantages in curing time and being able to use it overtop of other products, although recommended to get the paint down to basics before you apply it. An advantage that I believe the Last Coat has is that it does not have a bad smell to it and you could app,y it with the garage door closed.
I have read about a number of other products and was surprised to see such great reviews on the Turtle Wax Seal and Shine. It also seems to do a great job, is less expensive and is available in local stores.
It will be awhile before I can wash the truck again, but as much as i like the Last Coat line up of products, I will go with either the 303 or Turtle Wax Seal and Shine.
How do you safely remove any existing waxes?
I used Optimum Paint Prep. After washing and drying your truck you just wipe it on with a microfiber towel and that will strip away the wax.
JaysOnTheEDGE
Jay
Office Equipment Technician
Can you do a IPA wipe instead of using a paint prep spray? i have lots of 99.9% IPA
Fawnbuster
Indiana
Retired 34 years as LEO
I finally got around to using the new 303 Graphene last night and this stuff is really great. You can coat over any product including ceramic coating with this stuff. I wanted a fresh start so I washed, clayed and striped the old finish off with paint prep. The Graphene goes on very easy and you need to do a crosshatch pattern, you only need a few sprays on a microfiber pad or foam pad. I put way to much on the first panel and it was dripping and took forever to dry…less is more!
It takes about 10-15 minutes to haze over depending on temps and humidity so you can do about 1/3 of the truck then go back and buff out. It’s safe for all areas so I did all the glass, rubber around the windows and the headlights and taillights too. It gives you a super smooth mirror finish with great UV protection. I ended up doing a second coat just for added protection and you can clayed up to 3 coats. You can also use your favorite speed detailer or gloss enhancers after 1 week. The nice thing is there is no curing time like ceramic coating so once you’re done you can drive it right away. It can also be applied in direct sunlight which I wouldn’t recommend so it’s very user friendly. It’s supposed to last for 1 year and being a new product there’s no real world data yet but I’m confident it will as 303 makes great products and stands behind all of them.
https://www.goldeagle.com/303-graphene-nano-spray-coating/
Looks fantastic Dave!
Yes that works great too. I didn't have any so I just used this stuff.
CO2Ranger
The important question is...did you coat the damper? Inquiring minds want to know!
Well of course I did.....You really think I wouldn't. lol ?
I will have to invest in it! How's it do on plastic? Any haze or residue?
None what so ever. I used it on everything even the headlights and taillights. It works great on glass too, way better than Rain-X.
Motorpsychology
Prescott, WI
Vagabond
It's been about 6 weeks since I Graphene my truck and took advantage of the nice 70 weather today and washed it. I know it's only been 6 weeks but it beads up really good where I've had other products fail mostly because of the sun out here.
Motorpsychology
Prescott, WI
Vagabond
Beautiful finish, Dave. It looks like it was anodized.
Thanks Chris! I'm really happy with the Graphene so far as nothing usually last to long out here. The real test will be over the next 6 months through our summer heat but I did do two coats for some added protection.
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
This is mine a day after the first coat:
I did just the roof at the time. Here's the hood where I hadn't applied it yet:
So it beads well. This was on top of a carnuba wax that was on a week or so.
