2WD ranger snow chains recommendations
jflogerzi
Moreno Valley, CA
I am going to be heading up to the mountains this Christmas and want to be prepared for snow or bad weather that requires snow chains.
Muffin1
NJ
I had a set many years ago and can't remember the brand name but they were a cable type not an actual metal link chain, only needed them twice they worked well.
IdahoRanger
Idaho
2019 Lariat SuperCrew FX4
RETIRED
EJH
Ed
Subarus, 2021 Ranger
Get the quick fit type from Les Schwab. If you do not need them, and they are unused, you can return them at the end of the winter.
Since you have 2WD, I strongly recommend putting a lot of weight in the rear.
Ugly_Betty
PNW
2019 Ford Ranger Lariat FX4
Have a set of these. Work fantastic. 5 minutes to install them, less to take them off. Threw them on and plowed around in a snowy field nearby last year, keeping it in 2WD. 350 lbs. of sandbags in the back helped too. These are also on the approved "chain" list the the state police here in WA.
https://autosock.com/
jflogerzi
jflogerzi
Moreno Valley, CA
I do have the locker but I can get some Sand Bags as well. I just want to be prepared and not get forced into a bad situation :)
sn95joe84
Redmond, OR
Ford Ranger XLT
Physical Therapist
Silly question but... with 4WD, would it be better to put chains on the fronts or rears?
Wes Siler
Wes
Bozeman, MT
WesSiler.com
Writer
Note that all needs are not equal. Are you actually trying to drive around with them on, or carry something for emergencies?
I'm about to head up to our place in Glacier. It's going to be -30 with -50 wind chill...
Obviously I run real winter tires for 99% of the driving, and carry Maxtrax, recovery gear, and have a winch. But, our driveway is steep and tends to get icy. So, for that obstacle I carry v bar chains.
https://www.etrailer.com/Tire-Chain...Yjm6XRb2TDa7ZPC6wx1xWqvvyHiK-uJxoChZIQAvD_BwE
They are GNARLY and probably shouldn't be used over about 15 mph. But there's nothing else with that much grip.
If you're trying to drive around with chains on, look at a set of cables instead. Plenty of grip for most stuff that the general public might see, and they're way easier to use.
Old thread but for anyone searching, I love these snow chains. I've used them only a few times on my 2WD XL with stock steelies and they're easy to put on and take off (I've since bought a dedicated kneeling pad for this and other uses, rather than using my often dirty floor mat).
König XG-12 Pro
ergoKneel
pismo1
Temecula,Ca
2020 FX2
I onder how long they last.Pretty easy install when cold/hands.
I'm no fan of those autosocks BUT they do seem to work well on snow over ice. And, as an emergency aid, they take up much less space and weigh far less than chains.
From that perspective, I can see how helpful they can be. Unless you live in an area that routinely needs chains, the socks are probably a great addition to anyone's emergency gear.
Just like the safety triangles and flares I carry, it's nice knowing you have them and hopefully never need them.
From what I gather, the socks last well as long as you're in snow and maintain a moderate speed. Once you get on dry pavement, I believe they tear up quickly.
But, a plus side for socks in an emergency kit, you don't have to worry about them rusting! =)
