2020 Ranger Ghost touch/A. Auto issues
Ranger3
Ranger3
Dj
New jersey
2020 Ranger Xlt Sport 4x4
Store Mgr
It's definitely not moisture. Never was wet.
RangerBill
That's what I'm thinking. Also....do h think I should also change the USB ports? To help with the android auto issue?
I would try a new high-quality USB data cable. They can become intermittent. For your other problem, try disconnecting the battery cable for a few minutes.
Ranger3
Ranger3
Dj
New jersey
Store Mgr
Any safe place to get a new screen?
ScarzRanger21(2.0)
Eric
Auberry, CA
Electrician
That’s weird. You might just be one of the few that got unlucky and have a defective touchscreen. Not something I’ve heard of before with these trucks but I guess anything is possible.
Before you pull out the USB ports and replace them, I would try a different cable or maybe try resetting your phone to factory settings. I was having issues with sync for a while, it ended up being a setting that got changed when my phone updated. I restored it back to factory settings, deleted and re-paired my phone to the truck, and everything has worked fine since.
Grandaccess
Binghamton, N.Y
Computer Consultant
Hello all it's been a while....got this truck from the beginning.....had occasional AAuto disconnecting. I would pull the plug and put it back in and would be fine. The last month the touchscreen is ghost touching like crazy. I hard booted it. I soft booted it. To.no avail. It will go a day or so then come back. Hangs up on my wife lol all kinds of things. My thoughts are could this all be because of the degrading of the touchscreen? My first thought is replacing the touch screen and possibly the USB ports to fix the issues?
Have you tried just Cleaning it?
I had someone touch mine after eating a donut and left some smudge and it was doing that
Grandaccess
Binghamton, N.Y
Computer Consultant
Sync is up to date and nothing was ever spilled. It's a real thing...I guess this forum is truly stumped on this one.
Give them time to sleep on it for a night or two, one of our guys will solve it :)
tentspast
Australia
2020 Ranger XLT
It sounds like your touch digitiser is on the way out. as a last resort you could pull the head unit and check the ribbon cable, clean the contacts at the end with contact cleaner. New touch digitisers are pretty cheap as a replacement part, just search Ranger 2020 Sync 3 Touch Screen Replacement. There are also some decent upgrade options with larger screens that integrate with the vehicle systems (AC controls etc) and give you a built-in Android operating system.
I don't think your AA connection issues would be related to the touch screen.
Hope this helps!
OCL
Mission Viejo, California
2021 Ford Ranger Tremor
Now you are sure your truck isn't haunted right? :LOL: Because that would be quite freaky to see the screen acting like someTHING is touching it.
When you did a Google Search, was there any results on possible causes and fixes? If there is a known fix then you're not the only one who's had this happen. I can't help since my '21's touchscreen has been 100% since new.
Ranger3
Ranger3
Dj
New jersey
Store Mgr
Well it's not haunted and yes I need to replace the screen and digitizer.......heard it's common for Ford sync 3 in 2020
