2020 Lariat Front Turn signal LED
taildraggerpilot
Carl
Kennesaw, GA
2020 Ranger Lariat FX4, 2022 MINI JCW Hardtop, 1967 Mooney M20E
Boeing Guppy Driver
Do all of these LED bulb swaps need resistors?
CHS
chris
Crossville, TN
(Ruby) 2021 Ford Ranger Lariat 4X4
JACKSMYDOG
Jay
Ontario
2020 Ranger Lariat FX4 Black
I'm in the process of completing the LED update to all halogens in the Lariat and wanted to post the difference in speed and brightness of the LED.
The Halogen turn signal is definitely brighter which is advantageous during the day and less a problem at night.
I used the XP80 from Diode Dynamics which is a simple install. DiodeDynamics XP80
This is the speed and brightness difference. Left is Halogen, right is LED:
Halogen vs LED
This is both LED combined with the factory LED rear turns.
Both LED
With FORScan you can fix the fastblink in the cab thanks to @j0shm1lls
BCM - 726-27-01 x0xx xxxx xxxx
An interesting note, I didn't get fastblink with the hazard lights only the turn signals.
I generally don't change factory lights, but those signals are incredible. Ima definitely getting those, nice find.
I already did the fender markers, purely for day time cosmetics though. Even off, the orange marker really stood out. Smoked looks great on a black truck.
taildraggerpilot
Carl
Kennesaw, GA
Boeing Guppy Driver
CHS
chris
Crossville, TN
So, just to be clear, these LED lamps can be swapped out without resistors added in-line? Is there still a need to use ForScan to code the hyperblink? Thanks for your guidance.
The Link I provided for the Oxilan 2 pk do not. Just swap them out.
The fender and mirrors also did not. (The other link with the 10 ok)
No foreskin needed.?
JACKSMYDOG
Jay
Ontario
Kataphrakt
Tim
Grand Rapids Michigan
Ranger XLT FX4 Offroad
Mechanical Engineer - Mirrors
Bit late for the info on cap removal, but here you go:
I'd suggest using a plastic or wood spudger instead of the metal screwdriver i used, but i dont care about cosmetically damaging the mirrors in my case. The second time i break out the screw driver in the video it was not needed (I thought the bottom clips might have been engaged still), you just have to pull at the correct angle, gently wiggle it a bit.
raynmary93
Ray
Chesterfield MI
2021 Ranger Lariat Tremor
Yes, just replaced mine yesterday with these, no hyper flashing, worded as normal
Bobby-C
Robert
Indiana
2019 Ford Ranger Lariat
Local 1 Chicago IL Ironworker (retired)
Bobby-C
Robert
Indiana
Bobby-C
Robert
Indiana
You need to start at the outside top edge of the cap prying at the seam with a trim tool (plastic). Work your way towards truck slowly, top should open for you, and it will come off. That how I got mine off 2019 Lariat.
