- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,512
- Reaction score
- 8,608
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
The Pinpoint Tests, never directs you to perform a voltage test, they do not even give you what the voltage should be (feeding the sending unit) It is a Ref Voltage though and most likely it is 5-VoltsJust curious because I didn't see it reading this thread. Do have your reference voltage all the way back to the tank at the connector?
Being he got a temporary reaction with the fuel system cleaner, points to the resistance scale.
You could test for voltage on the easiest connector to access and that would be C410 Pin #3, however I am not sure if the IPC, shuts the voltage off to the circuit in a failure mode (default) to Empty. which will have codes P0460 (-11) or (-13), these 2 codes is what generates the Default to Empty Gauge.
This is where the IPC Self-Test and Scan Tool (Command) on the Gauge ties in to see if you can possibly reset the gauge to working.
As far as the Fuse (Fuse 13 -BCM) is a shared fuse with the IPC, SCCM and GWM, and pulling this fuse for 1 -minute just removes power from the IPC to allow a complete full power dump and reset itself at key on (reboot)
