2019 Ranger Completely Dead, Then Fine minutes later
priceman14
Midwest
Automotive
My truck drove fine to and from work today, parked it in garage. Realized I left something in the truck, so I went back out to it - it would not respond to the keyfob at all. I wondered if the fob's battery died.
I got into the truck with the manual key - tried starting it with the key, and nothing, no chime, no lights, nothing on the screen, no crank, the truck was completely dead. I went back out less than 10 minutes later. As soon as I opened the door, everything lit up light normal, except for a warning to start it with the key, or else the alarm would go off. It started perfectly fine, no setting were lost, and it immediately synced to my phone.
I used a multimeter to check the battery, 14.95 volts when running. With key off, after several minutes, it ranged 12.5 to 12.3 to 12.38 volts. I'm giving it an hour to see how it does.
The battery is just over 2 years old, a Die Hard from advance auto. The last time the 12V was bad, I at least got the dash to light up, and it just had the lights get dim when it tried to crank.
I'm wondering if this was an issue due to an Over-the-air update? A google search mentions things like loose battery terminals, run-start relay corrosion, or battery management system issues.
Is this a common issue? I did a quick search on this forum and didn't immediately see something similar.
Thanks!
IdahoRanger
Idaho
2019 Lariat SuperCrew FX4
RETIRED
There have been other instances and a few threads with the same thing happening. I think @airline tech figured out the possibilities for this to occur.
Also, my truck warned me when the fob battery was low.
In almost 7 years of ownership, my truck has done it exactly once. I think those who have experienced it have had similar results. It is a weird one for sure....
JimG_AZ
Phoenix, AZ
2021 Ranger XLT FX4
My Ranger did this a few months ago. I tested my battery and it failed the health test on the tester. It has not happened since I replaced the battery.
johnitahoe
Lake Tahoe
2019 Ford Ranger Sport/FX
Yesterday. I tried to open my truck with the key fob. Hit unlock nothing happened. Hit unlock again nothing happened. The third time it unlocked and worked as it should. 2019 Ranger XLT FX
Langwilliams
Langley
Lorain, Ohio
It happened to my '19 once in the 3.5 years I owned it. If it would have happened again I was going to try remote starting it with the app to "wake it up"
