12 volt plug in BED
OregonRangerTremor
Craig
2021 Ranger Tremor/2022 Bronco/2006 ChargerDaytona
Retired LEO/Dog Trainer
sklnbnz
Graham
Arizona
2020 Ford Ranger XLT 4x4 Sport
Adventure Ranger
Saskatchewan, Canada
2020 Ford Ranger Lariate Crew Cab FX4 Sport
Heavy Equipment / Truck shop Foreman
Had that been available a year ago I would have definitely installed it! I cut a hole and installed the factory 12V plug in my box.
micl9
Apex, NC
2019 Ranger XLT Fx4 302A
Its awesome - buy it
And use search there are a few threads where it is discussed
It was, works great. He has it with a split harness so you can tie in bed lights as well.
OregonRangerTremor
OregonRangerTremor
Craig
Thanks you....I just ordered it. Heck....my Ranger is not even built yet:crackup:
CB750F
Qc
Human
Great add on.
Quality part..
Simple to install.
I have tested it but I have no idea when or for what I'll use it for :LOL:
ksuds49
Kevin
Central Valley California
2021 Ranger Tremor & 2005 Land Rover LR3
Do things for peoples
That was my first mod ?
BILKO
Bill
Philadelphia
2013 Ford Fusion, 2019 Ford Ranger
Hey everyone I've been working on a factory looking 12V 20 amp socket for the bed that doesn't require cutting into the bed or splicing into wires. It also doesn't require any adapters. It uses a heavy duty socket and 14awg well insulated copper wire. It's a super simple install that only requires tightening one stainless steel bolt. The socket housing is also sprayed with truck bed liner. Below is a link to the listing I have on eBay. Check it out and message me if you have any questions. I'm also looking at selling the same setup with I long pigtail so you can run it to the battery or fuse box. Let me know if you are interested.
Look at this on eBay
https://www.ebay.com/itm/2019-2020-...=p2349624.m2548.l6249&mkrid=711-127632-2357-0
bentroia
Ben
Auburn CA
2021 Ranger Tremor
Logistics
Did you just copy Wolf Haus? If not what's the essential diffrrence?
https://whor.us/store/p/v2-aux-bed-power-harness-w-pigtail
Cabose-1
Eli
Student
Wolf haus plug is one of the easiest best mods to do to your ranger. And if you get the plug with pigtails.....use the extra wiring to do whatever, like bed lights! Good purchase, lots has been done with them, just go to the
What did you do with your ranger thread
BILKO
Bill
Philadelphia
The mounting location is the same but how it is secured in the location is different. I designed it to use a single adjuster bolt that wedges the assembly tight in place. The bolt is also stainless steel and hidden on the back side of the assembly. I also fit an actual cigarette/marine plug in the location so there is no need for an adapter. My setup is also rated for a full 20 amps. I use a high quality socket and 14awg copper wiring. I'm sure WolfHaus' setup is great but I wanted to do something that could handle 20amps and didn't need an adapter to make work with a car plug. I originally made it for my truck and thought I would offer it to others so they can have a nice factory looking plug in their bed.
bentroia
Ben
Auburn CA
2021 Ranger Tremor
Logistics
Sounds great! Thank you for clarifying.
