TJC
- First Name
- Tony
- Joined
- Aug 28, 2020
- Threads
- 45
- Messages
- 3,946
- Reaction score
- 9,914
- Location
- North Carolina
- Vehicle(s)
- 93 Miata, 05 Ranger 4x4, 20 Ranger 4x4, 23 CX-5
- Thread starter
- #1
This thread is to intended to document my attempt at enhancing the cooling of the 10R80.
I've already gathered what I thought I needed to install a transmission cooler in my 2020 Ford Ranger.
And I've already removed the front end covers and grill of my Ranger. Then test fitted the cooler that I had purchased. It's too tall to work in the location that I had chosen, so I went on to purchase a second cooler, and moved the mounting location to the area below the intercooler. The new cooler should be arriving later this week.(I'll use the old cooler in my 4G Ranger to protect 2 year old (10K miles on it) Jasper remanufactured transmission.)
I'll try to keep posts current, but there is a lot of effort involved to find the best routing for hoses, and installation of the cooler itself.
I'm going to be using AN8 PTFE hose and fittings. Pictures of the parts and pieces will be coming as I do the work.
Here's the projected ROI... and why I am beginning / attempting this project... from a practical, financial, and performance perspective. I’m considering costs, benefits, and risk mitigation, then I'll finish with a clear summary.
I'm not one of the lucky ones who has not had issues (I still can't believe folks have reached 150+k without transmission issues)
Costs (Out-of-Pocket)
Approx. Cost (I'm already over by $115, but I'll use the part on my 2005 Ranger.)
a) Transmission longevity
b) Reduced maintenance costs
c) Performance and peace of mind
Risk Mitigation Value
Think of this as “insurance”:
Risk Likelihood Cost if it happens
ATF overheat → clutch damage Towing / Hot NC summers $2,500–$3,500
Fluid degradation → valve body wear High over 25K+ miles $500–$800 per rebuild/flush
Even if the cooler prevents one major repair, ROI is already extremely high.
Financial ROI Estimate
Let’s assume:
Cooler cost + materials: ~$400
Avoid one clutch rebuild at $2,500 (conservative)
That’s >500% return if it prevents a single major failure.
Even if it only extends fluid life and reduces minor wear, it still saves hundreds per 10K miles in ULV fluid replacement and early servicing.
Non-Financial ROI
I'm not going to be updating this thread daily. Only after reaching a milestone or two along the way. If I fail to successfully complete the project, you'll know why. But I think I can pull it off. I'll then document the results. We'll see if it is truly worth the effort.
Mishimoto 13-row cooler $150
AN-8 hose & fittings (4×90° elbows + hose) $100–150
Hose clamps, separators, brackets $125
Aluminum strap, grommets, foam seals $20–40
Labor / personal time Variable (I'm getting old! What used to take me 2 hours now takes half a day
Benefits / Value Addeda) Transmission longevity
- Reduces peak ATF temps by 30–40°F under load (hopefully a tad more)
- Protects ULV fluid from thermal breakdown, extending service life
- Reduces clutch wear, which is one of the most expensive components of the 10R80 to replace (~$2,500–$3,500 in labor if failed)
- Fewer early fluid changes: 95%+ flush (Hopefully double the usual interval of 20K miles)
- Lower risk of unscheduled repairs — preventing a single major rebuild is worth hundreds to thousands
- Transmission operates cooler and more stable under towing or aggressive driving
- Reduced slip → more efficient power delivery, smoother shifts
- Real-time monitoring with my ScanGauge III allows proactive intervention
Let’s assume:
Non-Financial ROI
- Peace of mind: I can tow or drive aggressively in hot conditions without worrying about transmission damage.
- Data-driven control: Real-time monitoring allows me to catch issues before they become costly.
- Vehicle longevity: Cooler fluid → cooler clutch packs → longer transmission life, which keeps the truck more reliable and resale value higher.
- Financial ROI: Extremely high — likely >500% if it prevents a single major rebuild.
- Performance ROI: Moderate-to-high — smoother shifts, lower peak temps, better durability.
- Risk mitigation ROI: Very high — protects the transmission under heavy loads and NC summer heat.
