FORScan Crowdsourced Wiki
rangerdanger
SF Bay Area
Let’s post here useful FORScan modifications for the 2019+ Ranger
In case you forget what the original setting was... Lookup Module Build Data (As-built) by VIN: https://www.motorcraftservice.com/AsBuilt
As of 5/11/2019 Much of this (not all) is built into FORScan as "Service Procedures". You should no longer have to manually edit the as-built data as there should be easy to use menu options available.
OBDII ADAPTER:
This is recommended as it was developed with the team at FORScan. https://www.amazon.com/gp/product/B081VQVD3F/ -- (RCMUSTANG)
https://smile.amazon.com/gp/product/B083FML519/ -- (Gizmokid2005)
Note that in the table below, the "Setting" is the name of the GUI option in FORScan in the appropriate module location. You do not need to use the AS-BUILT data (nor modify it) if you use the GUI settings instead. They all exist unless otherwise noted.
SettingDescriptionModuleAS-BUILT CodeCredit
AM FM MenuDiables AM/FM Menu in Entertainment Screen (Lariat Only)IPCRCMUSTANG
Auto Relock Time DurationEnables 30 or 45 second auto relock if doors unlocked with keyfob but are not opened. Works with double-honk disabledBdyCM (BCM)Porpoise Hork (Upd: Gizmokid2005)
Average Speed DisplayDisplay average speedIPCRCMUSTANG
Average Speed RPMDisplay average RPMIPCRCMUSTANG
BMS / Auto Stop Start SystemDisables the Auto- Start/Stop system
NOTE: The button and dash indicators still function but do not do anything.
BdyCM (BCM)726-48-02 (x#xx xxxx xxxx)
0 - Off (Permanently)
1 - On (Default)
Gizmokid2005 / Akshon (AS-BUILT)
Chimes - [Driver/Passenger] Belt MinderDisables seat belt reminder charms (Two settings in non-AS-BUILT)IPC720-01-01 (xxxx xx#x xxxx)
0 - Both
2 - Driver
4 - Passenger
Chimes - Vehicle Running Door OpenDisables chime when door opens with engine runningIPCRCMUSTANG
Chimes - Primary SourceSelects the primary source for chimes. Defaults to speakers.IPC720-01-01 (xxxx xxx# xxxx)
0 - Internal Speaker Only
2 - Forwarded to ACM/Vehicle Speakers (Default)
NOTE: IPC Only will NOT have automatic audio mute feature for chimes/warnings (Depending on firmware version)
RCMUSTANG (Upd: Gizmokid2005)
Climate MenuClimate View on Lariat right side instrument screen (Cannot change climate, only for view.)IPC720-05-01 (D8B8 xxxx xxxx)John Galt
Corner Light Mode for Fog LightsTriggers fog light based on steering input (left vs right illuminated)BdyCM (BCM)Gfitzge2
Dark CarPolice option (Enable in conjunction with Silent Mode Control Menu)BdyCM (BCM)726-32-01 (xxxx x#xx xxxx)
0 - Disabled (default)
1 - Enabled
NOTE:
IPC:
720-04-01 (xxx# xxxx xxxx)
0/1 - add 4 to the value as shown below:
4 - Disabled (default)
5 - Enabled
RCMUSTANG
Daytime Running Lights Includes ParklampsEnables parking lights when DRLs are on (useful for raptor style lights in grille)BdyCM (BCM)Gfitzge2
Disable Front Turn Signal Hyperblink (No GUI setting as of 2.3.37) - update: now can be disabled under BdyCM "Front Bulb Turn Outage" settingDisables the hyperblink indicator when a bulb is out or LEDs (without resistors) are used in front turn signalsBdyCM (BCM)726-27-01 (x0xx xxxx xxxx)j0shm1lls
Disable Rear Turn Signal Hyberblink (XL Trim) (No GUI setting as of 2.3.37)Disables the hyperblink indicator when a bulb is out or LEDs (without resistors) are used in rear turn signals on XL models onlyBdyCM (BCM)726-28-01 (x0xx xxxx xxxx)j0shm1lls (unverified)
Disable Startup Chimes (3x doo-doo-doo)IPC720-01-02 (xxxx x2xx)RCMUSTANG
Double Honk on Leaving CabineDisables the double-honk when closing door with key in.BdyCM (BCM)726-41-02 (xxx0 xxxx xxxx)Gizmokid2005 / j0shm1lls (AS-BUILT)
DTE Calculation option in Productivity ScreenIPCArron
Fog lights if High Beam is on (AKA - Bambi Mode)Allows the fog lamps to stay on when the high-beams are used.BdyCM (BCM)726-27-01 (xxxx xxx0 xxxx)Gizmokid2005 / RCMUSTANG (AS-BUILT)
Front Bulb Turn OutageCan be used to disable instrument cluster hyperblink if switching to LED bulbsBdyCM (BCM)RCMUSTANG / SVTPaul
Frost Telltale (Below 5°C)IPCArron
Fuel Consumed Per Hour DisplayShow fuel consumed per hour instead of instant MPGIPCRCMUSTANG (Upd: Gizmokid2005)
Instant Fuel Economy DisplayChanges instant MPG display between bar and numeric displayIPCArron
Intelligent 4WD Gauge(Partially works (shows trail mode option selected) but does not show individual wheel response) (enable in conjunction with Intelligent 4WD Gauge Mode Feature)IPCArron
Intelligent 4WD Gauge Mode Feature(Partially works (shows trail mode option selected) but does not show individual wheel response) (enable in conjunction with Intelligen 4WD Gauge)IPCArron
Low Beam OutageBdyCM (BCM)RCMUSTANG
Navigation in MotionSpeed limit signs will look European and FM radio stations will be 2 decimals (101.70 vs 101.7). 911 Assist will be disabledAPIM7D0-02-01 (5753 xxxx xxxx)John Galt
Off Road GaugeEnables Off-road gauges (enable in conjunction with Off-road Screen)IPCGizmokid2005
Off-road ScreenEnables off-road gauges (enable in conjunction with Off Road Gauge)IPC720-07-02 (x3xx xxxx xxxx)Gizmokid2005 / WhiteLightning19 (AS-BUILT)
Panic ActivateChanges behavior of Panic Button behavior on KeyFOBBdyCM (BCM)726-37-01 (xxxx xxx# xxxx)
0 - Panic on FOB Disabled
1 - Panic on FOB requires 2 presses
2 - Panic on FOB Enabled (Default)
Gizmokid2005 / AS-BUILT info uncredited
Park Aid Control FrontIPCRCMUSTANG (Upd: Gizmokid2005)
Park Aid Control RearIPCRCMUSTANG (Upd: Gizmokid2005)
Power Point Timeout, sThe timeout period for the power point in secondsBdyCM (BCM)726-39-01 (0001 0101 006A) - For 1 second timeoutRCMUSTANG / John Galt (AS-BUILT)
Radio Without Ignition SwitchAllows radio use without the ignition (Enabled by default)APIMRCMUSTANG (Upd: Gizmokid2005)
Radio Without Ignition Switch play timeTime (in minutes) to allow the radio to run without shutting down or ignition on. (20, 30, 40, and 60 minute options)APIMRCMUSTANG (Upd: Gizmokid2005)
Rear Bulb/LED Turn Outage(Bulb or LED option depending on model)BdyCM (BCM)RCMUSTANG (Upd: Gizmokid2005)
Secure IdleTo idle the car with the key not in vehicle, cannot shift from park)BdyCM (BCM)726-42-01 (x1xx xxxx xxxx)John Galt
Selectable Drive ModeEnables the Terrain Management selectable drive modes (requires TM enabled 4x4 control knob)IPCGizmokid2005
Silent Mode Control MenuIPCArron
Software Engine Sound EnhancementDisables the "piped in" sound through the speakersACMGizmokid2005
Splash ScreenSync 3 Boot/splash screenAPIM7D0-02-01 (xxxx x#xx xxxx)
3 - Lincoln Black Label
5 - Raptor
6 - Mustang
9 - GT350
B - ST M
C - RS M
D - GT Car M
NOTE: There are others in the spreadsheet linked but I did not try them.
John Galt
Steering Wheel Switch PacksSCCMLeft Switch:
724-02-01 xx#x.xxxx.xxxx
1 - Standard Cruise
2 - ACC
Right Switch:
724-02-01 xxx#.xxx.xxxx
0 - Lariat Media
1 - Standard Audio
SOHK_Alumni
TPMS Placard Pressure DisplayDisplays the factory placard tire pressure in the Tire pressure display.IPC720-04-01 (xx#x xxxx xxxx)
8 - Enabled (show placard value)
Trailer Tow LIghts OutageBdyCM (BCM)RCMUSTANG
Variable Line Level AudioEnables variable line level audio output on the non-B&) radioACM727-01-01 (xx50 xxxx xxxx)Ed Venture
Vehicle Cluster ImagesChanges vehicle image between Truck and SUV (Utility / SUV)IPCRCMUSTANG (Upd: Gizmokid2005)
Welcome Goodbye BacklightingNo Blue Sky Background on IPC when getting into vehicleIPC726-03-02 (xxx4 xxxx)RCMUSTANG
Andy & WLFPIR8 (For the write up)
Enable Speed Limit Sign Display (Read by camera) in Lariat.
https://www.ranger5g.com/forum/threads/forscan-modifications.1844/post-143642
This is a link to the F150 Excel spreadsheet with all of their mods, its very thorough and technical, I have tried some not all obviously. Proceed with caution if venturing into the unknown. -- (John Galt)
NOTE: FOR INTERNATIONAL RANGER OWNERS. There are many differences with those models and what works with the North American version. This website can answer or has done many of the requests I've seen asked here. They are based on international Rangers. https://www.saeb.net/index.php
Jerva
Jeremiah
Guam
Ranger XLT 4x4 SuperCrew
US Navy
So ... what does this one do? Just curious. Thanks!
Dark Car Mode (Police Option)
Strokerduster
2019 ranger XLT, 2019 Edge ST, 1946 CJ2a street rod, shop full of motoorcycles
When you open the door the dome lights and stuff stays off instead of lighting up like the surface of the sun.
Also disables brake lights. Can't have those coming on in stealth mode......
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
Do we know if there is a permanent way to keep the gear display up on the small screen in the lariat?
That's only done through the PCM. Ie a tune. I had it done on my Fusion and will see if the BDX can do it for this as well. It seems that I have to push the shift button after it's sat for a while. Many times I come back to it and drive after a short while and it's still showing.
Geoff
NYS
'19 Ranger 1943 Willys Jeep
Retired Engineer
Yeah, same here. What's up with that. Heated seats settings are retained even if sitting for a day. My Fusion didn't do that.
RCMUSTANG
Ray
Los Angeles
Yeah, I need to find out if the memory for the heated seats can be defeated.
dguffin
Dana
Aberdeen, SD
20 Corsair, 19 Ranger, 12 Boss, 08 Zuma
Shop Foreman
I was wondering the same thing. Some of the other Ford vehicles keep it in the display all the time after it's been turned on.
John Galt
Prius
I can confirm that the F150 seat belt reminder disable mod also works for the Ranger, Also adding Climate view to the right side of the gauges on Lariat works! I use this so I can turn off the sync display and still see and adjust my climate. Finally, disabling startup screens or changing to any other ford screen works like the F150, I currently use the raptor one and its beautiful. Oh ya I almost forgot, secure remote start works too. The one where it wont let you take it out of Park if the key isn't in the vehicle.
djrobb
Alexandria,Va
2006 Tacoma 4dr Sport Long Bed
THis is great John, can we add them to the first post, the “Wiki”? Do you have the actual code changes? Just want to help the others.
Thanks to those that posted these updates. I was able to successfully do 3 of them tonight:
  1. Bambi mode
  2. Change the boot screen to the raptor theme
  3. Disable the double honk
First time I've done anything like this, but after a couple of false starts, it worked really well. Thanks again for sharing your knowledge!
