Worried
MannyS
Manny
Winder
2019 Ford Ranger XLT FX4
Wife drove the Ranger. Found out she had it 4WD on pavement. Now I'm worried.
Probably not a problem really. These trucks automatically drop out of 4WD at a certain speed. So it should be fine
MannyS
MannyS
Manny
Winder
That is good to know. What the speed do they drop out at?
quangdog
Kimball
Meridian, Idaho
www.youtube.com
2019 Ranger Lariat FX4
Uh... they do? I may be misinformed, but I did not think that was the case at all....
E Monty
Eric
Mitten
‘20 Ranger XLT/‘03 Excursion
Sheet Metal Worker
You may be confused with not being able to switch into 4WD past 65 or something close? I have never had mine “drop out” and I’ve driven close if not over 70 a couple of times.
EJH
Ed
Subarus, 2021 Ranger
Same here. However, the rear locker will disengage at a certain speed. That said, I've never been up to 70mph in 4WD :p
quangdog
Kimball
Meridian, Idaho
www.youtube.com
I'm pretty sure the manual says you can shift *into* 4WD at any speed below 68 mph. I've had my truck up to 75 briefly in 4WD on icy/snowy freeway without any issue. Certainly not something I do often, or really recommend, but my truck has never auto-shifted out of 4WD. Can't speak to the rear locker... I've only engaged that thing when crawling up a mountain... usually in 4 low.
t4thfavor
Chance
Can confirm 4x4 does not disengage at any speed. If she just drove a few miles on pavement all she did was shorten your tire life a bit.
If this can or did cause any problems
I wouldn't worry. As long as she didn't turn it hard and there wasn't any binding you will be good.
JAKE2.3
Jake
Pennsylvania
2019 Ranger STX, 2018 Mustang Ecoboost
Appraiser
Don't worry, should be fine. I've done the same before. Too easy to hit that knob with my knee for some reason.
MannyS
MannyS
Manny
Winder
How can I check for binding?
