Danager
Yesnoob question... can you tie both LED Pods Hot wires together and into one end of the butt connector and the pre rigged hot from the fuse box into the other end?
So one switch wire to 2 lights essentially?
Yes. At the end of the day how many items you tie to one connection is simply a limit of your wire gauge and relay and/or switch capacity.noob question... can you tie both LED Pods Hot wires together and into one end of the butt connector and the pre rigged hot from the fuse box into the other end?
I mounted the Baja Reverse light kit up to ground on the bracket itself for right now. The Ground wire isn't very long and I would of liked to have bolted it inside the tailight area but couldn't figure out how to get those bots out from where I was working.What convenient places are folks who are mounting on or near bumper finding to use for the chassis ground?
well done on keeping your truck clean inside! I need to get my butt out there and detail mine!They come factory in the Tremor package. I'm not sure how easy it can be added aftermarket.
oh I figured I’d ask the same question to you… Did you decide on the switches based on amps for the particular fuse?Looks great! I did ditch lights myself, also to ss6 bars in the bumper and one behind the grille. I used aux 1-3
I didn’t no, I used switches 1-3, I figured I’d move them if I ever needed something with higher amps installed. I should’ve just wired them into the lower amps, I think all my lights on each switch are sub 5 amps if I remember correctly.oh I figured I’d ask the same question to you… Did you decide on the switches based on amps for the particular fuse?
I would’ve liked to just start with number one personally, but my set up only needed 5 A, so number six kept all of the higher power options free.
I didn’t look into whether I could just swap them around… I didn’t know for sure if the actual wires were size accordingly or relays somehow…
Now the question is where the hell do I find a really nice looking tiny sticker that fits on each switch indicating what it’s for?!
I can’t believe it wasn’t as easy as typing it in. Seems like they have them for F2 50s and maybe F150… Basically the ones mounted on the headliner console.
I just don’t think they’re the same shape. Although it probably would still work
I think that’s a solid strategy because it definitely is easy to switch! I really did hate skipping over to the last switch. It just didn’t feel right.I didn’t no, I used switches 1-3, I figured I’d move them if I ever needed something with higher amps installed. I should’ve just wired them into the lower amps, I think all my lights on each switch are sub 5 amps if I remember correctly.
I’ve seen the repercussions… My buddy in high school did a little self wiring job. It just so happened that he was parked at my buddy’s house, and I happen to be right out by the sidewalk when he arrived.Not electrician but I do HVAC work, and get about 1 years worth of electrical schooling, so let me encourage you not to change out a fuse for a higher one.
If the wires are sized to the fuse as indicated, then you run the risk of overheating that wire, and catching ?. Just in case you wanted to check those wires, get the gauge size, and the type of wire, it may be written on the insulation, something like, THHN-8gcu.
I don’t know how automotive works their wiring. You may find this info on a schematic.
Once you find this info, compare it to a wire gauge chart from a manufacturer of wire. Many of these are found on the net.
