Tutorial: Tremor Upfitter Switches Always On
JDG
Conshohocken, PA
2021 Ranger Lariat Tremor, 2016 Fiesta ST
I have been interested in getting some of the tremor upfitter switches to function while the vehicle is not on for quite some time. Through some digging and testing in the vehicle, I have determined how it can be done and have implemented it in my 2021 Ford Ranger Tremor. Since I have received a lot of benefit from this forum, I thought it was about time I provide some benefit on a topic I have seen come up occasionally among other members.
I have seen a number of posts regarding these upfitter switches as well as wiring diagrams posted that are not accurate. What I have learned through my research and testing is that the Ranger Tremor Switches are identical to those used on the 2017-2022 Ford F-250 and thus have the capability of being wired in different configurations. The switch assembly part number (for reference) is HC3Z-13D730-AA.
I was also able to determine that the relay coils in the upfitter switch relay enclosure (in the engine bay) are always hot which makes this modification possible by only performing wiring in the passenger compartment.
Here are the configurations available:
  • Wire all 6 switches to be functional with the vehicle off
  • Wire switches 1-4 to be functional with the vehicle off
  • Wire switches 5-6 to be functional with the vehicle off (This is what I implemented on my truck)
The first step in the process will be to remove the switch trim panel and switch assembly: https://www.ranger5g.com/forum/attachments/auxiliary-switches-installation-pdf.164678/
In my case, to safely remove the 12-pin connector, I also had to remove the switch assembly from the trim piece. This required unscrewing all (4) T-25 torx screws from the backside. Below is a figure of the pin numbering for the molex connector as well as the wiring diagram for the F-250.
From the F-250 upfitter wiring diagram (and from testing), we know that pins 5 and 11 supply switched 12v power to the upfitter switches with pin 5 supplying switches 5-6 and pin 11 supplying switches 1-4. In the case of my vehicle, the switched +12v power supplying the switches was a yellow with violet wire for both pin 5 and 11.
So we know that we need to create a new wire that is always hot for pin 5 and/or pin 11 depending on which configuration we would like:
  • Wire all 6 switches to be functional with the vehicle off (wire always on +12v to pin 5 and pin 11)
  • Wire switches 1-4 to be functional with the vehicle off (wire always on +12v to pin 11 only)
  • Wire switches 5-6 to be functional with the vehicle off (wire always on +12v to pin 5 only)
We need to run the new 20awg wire(s) from the passenger compartment fuse panel (connected to an always on circuit), to the molex connector for the upfitter switches. The new wire(s) will need to be terminated with a molex pin such that the factory pin(s) can be removed and the new wire(s) can replace it. The molex part number for the pin is 34803-3212. The factory pin(s) that are removed can be covered with heat shrink tubing or electrical tape such that they can be reinstalled if we wanted to reverse this modification at a later date.
I opted to also purchase some spare molex connectors (P/N 34729-0120) in case I damaged the connector during this project. I ended up damaging the original molex connector on the truck while removing pin 5 and had to swap all the factory wires to the new connector I had purchased.
Final Result in Upfitter Switch Area (The red wire is my newly installed wire in the pin 5 position that is wired into an always on circuit in the fuse panel)
There is a simple path for our new wire(s) from the location of the upfitter switches to the passenger compartment fuse panel on the driver side under the steering wheel. You only need to remove the fuse panel cover to gain access to the area needed to run/secure the new wire(s). You will then need to connect the new wire(s) to a fuse tap. The fuses in the passenger compartment are Micro-II fuses.
I opted to install a 5A fuse into the fuse tap to stay consistent with the fuse sizing in the F-250 for this wiring. I also opted to use Fuse 16 for my always on power source. Note the orientation of the fuse tap is important during installation.
A great guide on the passenger compartment fuses can be found here: https://www.ranger5g.com/forum/threads/passenger-compartment-fuses.14754/
Final Result in Driver Footwell
Note Switch 5 & 6 are on (and lit) with vehicle powered off:
Parts Needed
Tools Needed
  • Panel removal tools for switch trim removal
  • T-25 Torx bit or driver (bolts are only hand tight)
  • Molex pin removal tool or small pick
  • Crimper for new molex pin(s) - I used a Delphi Packard pin crimper that I have had for a decade and it worked great
  • Butt connector crimper
  • Wire stripper
  • Butane torch or lighter for heat shrink tubing
  • Dielectric grease (for easier molex pin installation in connector)
  • Fish tape (Not necessary in my case but could be helpful for wire routing)
  • Needle nosed pliers for fuse removal
As always with anything that I post, anything you do to your vehicle is at your own risk. I will not be held liable if you do damage to your vehicle while following this guide. I will also not be held liable if you are hurt or worse due to this modification.
Please let me know if you have any questions. I hope this can be helpful for some of you.
les101ca
2023 Ranger Lariat Tremor
Wow thanks for the detail. I was wondering how to get maybe 2 switches hot all the time. You saved me a ton of investigation.
DonovanJM
Donovan
Washougal, Wa
Oh, nice! Thank you for the tutorial. This is something I may want to do in the future.
Reactions: JDG
Rub3n23
Ruben
New York
2020 Ford Ranger
Space Cowboy
Does anyone have a part number for the bezel itself? Would love to add these switches to my Ranger and have a factory look.
Mtn_Tremor
Grayson
2021 Ranger Tremor
You are the man! This has multiple dead end forum posts and you cracked it. Thanks for sharing in detail how to do this - can't wait to try it!
Reactions: JDG
ppfd
2021 Tremor
RN/Paramedic
LoL I have never used my switch panel in my tremor.
stev0
Stephen
arizona
Ford Ranger Tremor
Thanks for this! I just did this for some lights that I have installed on a sports bar facing back (for setting up camp) and this is great to be able to run the lights with out having to run all the auxiliaries with leaving the key in to do so.
Cheers!
Reactions: JDG
jdamtb918
Jon
Tulsa
2021 Ranger Tremor
HVAC Tech
Love it! Thank you sir
Reactions: JDG
LowKeyTremor
Kyle
Northern Cali
2022 Ranger Tremor Lariat
Business Owner/Partner & IT
Parts Needed
Tools Needed
  • Wire stripper
That’s solid!
I do have to say though, and maybe this is quite incorrect but I swear that I read within the auxiliary fuse compartment, there is a place where you can flip a little switch or some kind of connector, or do something… But anyways it switches it to full-time power
Has that been debunked? Has anyone even heard of it? If I have time I might go take a look, because it really stands out in my head but that doesn’t really mean much… I got a lot going on up there lol
Talk about a busy mind that loves to run! It needs to chill sometimes :)
LowKeyTremor
Kyle
Northern Cali
Oh and I love the fact that you have gathered info from here and now you’re paying it back with contributions of your own!
I hope I have some truly useful insight and can do the same because if we are all able to do that or at least as many as possible, this will be quite the source of info, which it already is!
When I was younger, I was on Mustang forums, due to my Cobra, and later on a GT convertible.
Then a Dodge Durango forum. Oh my gosh, I’ve never had such an ineffective enormous motor… That 360 was a dog! All it did was gulp fuel and disappoint me when towing my boat
Then I was on the infiniti forum - G 35
Right before this, a BMW forum - 440i Gran Coupé (translation, extremely sporty lines with a sport back trunk, but a four-door).
Loved that car! Not to mention, $1500 could easily put you at 450 RWHP if not more. Pretty amazing in-line six. That engine model, called a B58 (gen1) was one hell of a well built and designed engine
But after all of those experiences with forums, by far this is my favorite and stands out over all of the others! Absolutely has my favorite people and I mean just generally speaking, it’s a bunch of great individuals!
People on here are down to earth and genuinely here to learn and help! I love it and I love that the Almighty anonymous tough guy is not very common at all and I actually haven’t experienced it.
I just felt compelled to bring that to attention
