Who am I to believe? (Heads up 2019 owners)
VAMike
2019 Ranger Lariat SuperCab
Is this not the radiator/antifreeze drain plug? Thanks might replace orange with yellow.
why on earth would you crack open a sealed system for no reason?
Dmax
Denver, CO
2019 Ford Ranger Lariat 4x4
To put in the yellow coolant. 200k vs 100k life. Working on the truck is always fun. This truck is pretty easy to tinker with.
If you read the fine print if you replace the orange with the yellow, it will still be only 100k, not 200k.
harringtondav
East Central Iowa
Yep. Wait until 100K mi. By then something newer and better will show up. .....for the next 100K mi.
VAMike
Great...so wait until 100k and then change it
GregsFX2Ranger
Greg
2021 XLT 302A 4x2 Rapid Red Black Appear Package
Management
I got lost in the thread. So, can Zerex G05 be used in a 2020?
I have seen some of the older coolant caps separate like you are describing but that is usually due to high heat and ppastic not getting along.
quirkybar8
Indy
2019 Ford Ranger 2WD XLT
DY = Yellow-colored engine coolant approved to Ford specification WSS-M97B57-A1 or WSS-M97B57-A2 (Motorcraft® Yellow Antifreeze/Coolant) according to https://www.fcsdchemicalsandlubricants.com/quickref/coolantsEN.pdf.
G05 says it meets WSS-M97B51-A1 spec, according to the PI sheet from https://www.valvoline.com/our-products/antifreeze-products/g-05-antifreeze-coolant . That's an old spec, so it appears to be a no. (https://parts.ford.com/content/dam/ford-parts/resources/motorcraftpdf/Coolants_Brochure.pdf)
Besides, the cost is about the same, so why bother?
cocheese72
Florida
2020 Ford Ranger XLT Crew Cab
IT
Yes, you need this device. There is no direct way to get coolant back into the system. Just filling the reservoir won't work.
The service manual has a procedure for: Filling and Bleeding without a Vacuum Cooling System Filler.
Yeah.... About that procedure...... Its a great way to waist an entire day if you have nothing else better to do. The unfortunate truth as I have done that before!!
