Which 1" Wheel Spacer Do You Recommend?
quangdog
quangdog
Kimball
Meridian, Idaho
www.youtube.com
2019 Ranger Lariat FX4
quangdog,
One important item that Bluebeaststr mentioned and is worth repeating, is to make certain that whichever spacers you decide on are machined to be Hub Centric!
Yes, I agree that's important. That's why I mentioned the Bora and Faction Fab in my original question - both are hub centric, I believe. I've seen a bunch of other "universal" wheel spacers that are clearly not hub centric, and I'm not willing to even consider those.
I'm currently leaning towards 1" Bora. Anyone want to speak up in favor of either Faction Fab or 1.5" instead?
quangdog
quangdog
Kimball
Meridian, Idaho
www.youtube.com
Here's a link to a thread I made. It has a lot of pics. That might help with your decision. I wished I would have went with 1.5s instead of the 1 inch. Just for looks.
https://www.ranger5g.com/forum/threads/guys-running-a-1-inch-spacer.7505/
Thanks for pointing me to this thread. I've seen it in the past - looks like you have fender flares on your truck. I think I agree that 1.5" would probably look a little better with those flares. I'm keeping my fenders, tires, wheels all stock. I am pretty sure 1" will be just enough for me.
tgRanger
NJ
Can you provide more detail on this? Will a 1" spacer on stock hubs and wheels and tires really cause the hubs to wear out early? This is the first such warning I've heard about that....
Here’s a good video.. worth taking a look if you haven’t seen it.
Hounddog409
Tod
Ohio
F150
Been doing a bunch of research into wheel spacers, and I think I've decided I want to install some 1" spacers. I've got a Lariat FX4 with a 2.5" RC leveling kit installed. Running factory stock tires and magnetic 18" wheels.
First question: Will installing a 1" spacer cause any rubbing with stock tires and wheels? (I don't think it will, but wanted to see if anyone had more insight)
Second: What brand/spacer do you recommend? I'm looking at either Bora or Faction Fab from Stage 3, but would be happy to consider other alternatives.
Anyone have any thoughts?
Thanks!
You asked for thoughts...
Mine is dont use spacers.
mtsoxfan
NEK VT
I went with 1.25 Bora spacers. Brings tire to edge of wheel well. Glad I didn't go 1.5" only because of the mud slinging over side. I already bought Ford molded mud guards and should have gone with Rockblox (sp) as someone pointed out in another thread to prevent this. I do think it handles better with the spacers and the leveling I did.
The video was entertaining, but really didn't give more than an opinion. Yes, engineers designed for a reason. I don't race my truck, drive fast and hard, so I don't see a handling/braking issue for me. In fact, I feel mine handles better. I do, and will continue to check torque on spacers and wheels frequently. Will they wear prematurely? It's possible, time will tell.
StezenW
Stephen
Atlanta
AutobotXJ
Ray
Volcano, HI
2020 Ford Ranger
Wildlife Biologist
I used Spidertrax wheel spAcers on my XJ and did a lot of research before I actually started using them. My conclusion was that it doesn’t affect the wheel bearings any more than more offset wheels, however, as Phil mentioned, it introduces another joint that can introduce another link that can fail. Make sure that they are torqued correctly and they should be fine. I didn’t notice any adverse effects on my Jeep.
From the pics I see, I think 1” might not be enough, I might go 1.25” or 1.5” but Stage3 is currently sold out :(
StezenW
Stephen
Atlanta
Try Wheel Adapters USA. I got a set from them, and while they took 2 weeks to ship they were well worth the wait. Very high quality. And definitely get the 1.5!
VegasP11
Ian
Kansas
2019 Lariat FX4
That guy reminds me of a teacher I had that swore buying a Pentium was unnecessary because a 386 SX16 did the same thing. He had zero evidence other than changing things on cars is bad because it is not built like that from the factory.
Hi Ian,
What the fellow (Scotty?) inferred was that wheel spacers increase the scrub radius and you can expect accelerated tire wear and change is steering efforts in some cases.
apotocki
Alan
Rochester Hills, Michigan
2019 Ranger XLT
Network Force Analyst
I know I posted this in the ‘General’ Section under another thread but thought it might be helpful here as well.....
After much debate I ordered and installed Faction Fab 1 inch wheel spacers.
I was torn between these or Bora. The Faction Fab look to be high quality and all the specs seemed to reinforce that.
Ordered from Stage3 on Tuesday and on my doorstep Thursday! Kudos to Stage3.
I installed them today and wow - what a difference they make. I think the 1 inch is perfect bringing the tires out just enough - couple this with the 2.5 inch level and ‘this’ is what a Ranger should look like. I think I’ll be happy with them.....now just have to wait for the tires to wear so I can get bigger ones!
apotocki
Alan
2019 Ranger XLT
Thought I’d add this information as it might be helpful for someone looking at spacers and concerned over what size the wheels can accommodate.
Here are pictures of my front and rear hubs with 1 inch spacers.
Be aware that at least on my Ranger the rear studs are a bit longer than the front. I have no issue as the factory magnetic wheels have pockets on the backside. But....I think anything less than 1 inch (like 3/4 inch) would pose a problem and most likely require stud trimming.
I don't understand the comments on hub centric...my after market Fuel wheel center bore is much larger than the hub and the wheel is not centralized by the hub...so I must assume it's nut centric...6 nuts can do that job quite well...I've not experienced any off center vibrations in the 44k miles driven so far...as for the 1" spacers, Bora is the only one available and I have a full set on order....this is to bring my +20 wheels out another inch to match the stance of my new Air Design flares:crazy:
