Wheel Spacers - Difficult to remove?
Mostly Harmless
New York
2021 CG Tremor
Eventually I would like to wheel spacers to my Tremor but I am curious if anyone has any issues getting them off when they need to replace their rotors? Is anti seize recommended?
RangerPNW
Thomas
Santa Fe, NM
I've had wheel spacers on my 03 Explorer for years (they were free), and i found that they usually came right off. If not, it was usually a little surface rust trying to hold them in place and a little thunk with a persuader did the trick.
808matt
Matt
Hawaii
2019 Ranger FX4 Sport Package, 2015 f450 Bucket Truck
I put a very thin amount of anti seize where the spacer meets the rotor on mine when I had them on
Toytec
Central NC
Same here. But first I wiz wheeled the rotor surface clean then did it.
I like using Anti-Seize (I still have a tin of it from 30 years ago!) but Loctite ThreadLocker might be pretty effective and safe (I'd rather fight to get them off then to have my wheel pass me!). =D
The layer of Loctite will help prevent water and then rust from forming, and as said earlier, a breaker bar (and maybe a persuader pipe extension) should break them free.
awd.nv
Anthony
Las Vegas, NV
'21 Ranger XLT Tremor
Computers
The Loctite on threads is actually not recommended on the factionfab instructions.... It is logical though, think about it....Do you Loctite your wheel nuts? No, that is why we torque them down.
Stagg Jr.
Stagg
NY
2021 Ford Ranger XLT Crew Cab 4X4 302A
Retired (sort of)
I also plan on using Anti seize against the rotor.
As far as the spacers (1 inch) I'm going to us orange loctite and torque the studs to 100 ft lbs. Same with the wheels, 100 ft lbs.
Gsxrdoug
Hawaii -- Oahu
2021 ranger, XLT 4x4, Cactus Gray
Therapist -- Retired Navy
Careful with the loctite on the wheel studs, some spacers are very clear about not using any.
Stagg Jr.
Stagg
NY
Retired (sort of)
The video I saw on faction fab spacers the dude said to use loctite. I think Bora instructions say not to. Go figure...
Stagg Jr.
Stagg
NY
Retired (sort of)
He gets to the point around 3:40.
awd.nv
Anthony
Las Vegas, NV
Computers
Funny, the paper instructions said not too. I would need to go through my garage. To be safe, I would always recommend checking torque after the first few hundred miles.
