What do you use to clean the Tremor Side Steps?
Phil_R
2024 Ford F150 STX
Retired for now!
I think the team that delivered my vehicle from the muddy lot to the rail car must of had a blast doing so. Mud all over! I asked the dealer not to clean / detail my truck before I picked it up as I mentioned here before, however I still am cleaning mud from the truck underside and my porous Tremor steps. What do y'all use to clean the mud out of the steps? I have ended up using a high-quality car window cleaner and that has helped. Car was soap and scrubbing with various brushes did not do anything to get the mud streaks off that reappear after the steps dry. TIA for any ideas!
LB'sTremor
Loren
Tampa
22 Iconic Lariat Tremor
IT
Great question, I got some wax on mine and cannot find anything to take it off..
LB
JasonTremor
2021 Ranger Tremor XLT
Pressure washer works well on the textured steps after a soapy water pre-soak.
Also found that some soft bristle brushes break off fibers when scrubbing the textures steps.
NTXTremor
Dallas
2021 Ranger Tremor
IT
If you crawl under the truck, there are two bolts on each of the three legs holding the rails to the body.
Remove the bolts and the rails. Problem solved. :wink:
Phil_R
Phil_R
2024 Ford F150 STX
Retired for now!
Thanks Jason!
Phil_R
Phil_R
2024 Ford F150 STX
Retired for now!
Well Mark, with the less than a tall wife, that ain't going to happen, in my case anyway!
This ^
Also, let your calves and shins rub it off.
