Hank the Tank
- Thread starter
- #1
Before seeing member's posts on rust, I had already considered adding chassis cleaning to my maintenance schedule. I have recently started using Super Clean (degreaser) cut to 4:1 (water : degreaser) to clean underneath, staying away from rubber as much as possible. Wash off, let dry and then I use INOX Mx3 to lubricate and protect metal. INOX Mx3 is similar to WD-40, but it is non-petroleum-based. Both have roughly the same protection properties. With INOX you can spray it on electronics and harnesses to dissipate moisture (not sure with WD-40). I finish the underside off with silicone spray to the rubber bits. I'm just curious if anyone else has a bottom-up/top-down detailing or cleaning procedure.
This guy goes hard in the paint:
