y2krtaf
Gary
USA
2020 Ranger
Aircraft mechanic
Do yourself a favor and make sure you remove the axle nut and swaybar end links. It makes the installation so much easier. As shipped they raise the front 2" & if you want it higher adjust them before you install them.
Absolutely,did the same when I leveled it.Have a fresh pair of axle nuts waiting.
‘Truly not worth the risk for a pair of cheap nuts.
kevstaarr
Kevin
Los Angeles
2020 Ford Ranger STX FX4
Those Staun deflators are great! Once they're set, makes airing down so easy!
Glocker
Boca Raton
ARB Digital Tire Inflator Gauge - ARB601
For use with my air compressor. (see above)
Whoa! Wait a minute here! Tell me more!
Does this work in line with your tire inflator? Does it use the smaller, Japanese style quick release air chuck connectors?
I'm asking because I have a Smittybilt tire inflator, but the in-line air gauge that it came with it about useless. When airing up, I have to fill up the tire, take off the air hose, check the air pressure, put the air hose back on, fill it up more, take it back off, check the air pressure, put the hose back on, fill it up more...
You probably get the picture. :D
Glocker
Boca Raton
Swingpure
Gary
McDougall, Ontario
2020 Ford Ranger XLT Sport
My rear Weathertech floor mats arrived today. They fit like a glove. Originally I just ordered the front ones, thinking that I would use something cheaper for the rarely used back seats, but the cheaper options, just did not make the grade.
Weathertech all the way!
Accessories still to come, my Extang Trifecta Signature 2.0 Tonneau cover which is likely 5 weeks away and my bed extender which was suppose to come with the truck, but is back ordered and it’s arrival date is totally unknown. Hopefully sooner than later.
I am still debating on whether to get the tailgate lettering or not. I think they look great, but I have been trying to stick to getting functional accessories, at least for now.
KnightRanger
USA
2020 Ford Ranger, 2016 Harley FLSS,
Was excited to get these today. :D
Diode Dynamics Ditch light brackets
Baja Design S1 ( I like the low profile look)
Lightforce ranger switch fascia with switches.
Now...to find wiring access hole from cab to hood through firewall...:facepalm:
JAKE2.3
Jake
Pennsylvania
2019 Ranger STX, 2018 Mustang Ecoboost
Appraiser
I drilled a small hole in the upper right side of the rubber firewall boot where the main harness goes through. About the only thing I could come up with.
Glocker
Boca Raton
This is the tool I would recommend for breaching that firewall boot:
https://www.amazon.com/gp/product/B073WZCL8Q/ref=ppx_yo_dt_b_asin_title_o01_s01?ie=UTF8&psc=1
It's a little safer than a drill bit to lessen the chance of damaging the main wiring harness.
JAKE2.3
Jake
Pennsylvania
Appraiser
BHunted
Sumner County, TN
KnightRanger
USA
