OFC Ranger
Jack
ZR2
I also think his Ranger is an emergency wire supply for the area he lives in.
In case of the electrical grid going down, he has a ready supply of wire, fuses, diodes, blocks, ect...
Well my supplies are getting kind of low at this point about time to reorder some stuff.
I did have to fish in 8 gauge wire through the firewall this morning and that was an interesting thing to tackle when my wire insertion tool was only meant for 12 gauge or higher. 45 minutes later in a few busted knuckles and scraped hands and I got it done with some redneck engineering with painters tape.
Ended up having to run it through the passenger side firewall because the driver side firewall there was no room for my hand to get in there to assist my makeshift engineering get that damn wire through.
Venom_z89
Edson
So Cal
2019 Ford Ranger fx4
Forklift technician
Did a little cross referencing found that a mild upgrade that would be a lot less than a BBK. Our stock tb is only 61-63mm the 3.7 is 68mm and the 3.5 ecoboost is 70mm. Thought I'd throw that out there
Zeroedin
Matt
USA
2021 Ford Ranger Roush Edition
The harness is clipped into the sheet metal just beside where the wire passes through the opening. If you remove the original CHMSL, the wiring passes through a thick piece of tape. Remove that and you can follow the wiring with you hand - inside and to the left. You can pry that retainer clip out with a panel removal tool, screwdriver, pair of needle-nose pliers, something similar. There is some slack there. Once you plug in the new light, wrap the plug with some foam tape to prevent rattling.
Ahhh…..ok, that’s the path I was on but I started worrying that the clip fastened through the sheet metal might be holding the headliner in place (or serve another function) and was afraid once I popped it out I’d be past the point of no return……and getting into “Crap, my dealers gonna charge me a fortune to put this back together” territory.
I’ll revisit it this afternoon. Thanks for the input and feedback. Truly appreciated.
Aonarch
Alec
North GA/ Montana
Cabose-1
Eli
Student
E=MC2…….but
“This formula is valid only for low to relatively high speeds; for extremely high-speed particles it yields values that are too small. When the speed of an object approaches that of light (3 × 108metres per second, or 186,000 miles per second), its mass increases, and the laws of relativity must be used. Relativistic kinetic energy is equal to the increase in the mass of a particle over that which it has at rest multiplied by the square of the speed of light.”
So.......
The ranger is fast??
Cabose-1
Eli
Student
Hi Folks,
My Ranger had to perform some relative high speed evasive maneuvers today on the trip home on I 19. Three times we were attacked by huge, aggressive tumbleweeds trying to tag the front bumper and grill on the Ranger..... We had high cross winds and have never seen so many tumbleweeds being blown across the Interstate. Ranger handled well and we dodged all of the tumbleweed attacks. Can't say that for the semi trucks on the road....
Give me some of that pilot shit mav!!
KNI
Finland
Ranger Raptor 2021
E=MC2…….but
E=MC^2 gives out the correct value always.
Saying that it's value is too small is just stating that person doing the calculation does not calculate correctly as M would be M = m*(1/(1-v/c)^1/2)). You can't say that equation is faulty if you put wrong numbers in it.
And put the other way around a wave function can generate two particles of 1/2M=E/C^2 out of thin air.
Bob902
St. Louis
2021 Ranger XLT
RETIRED!!!!
I can spell cat and count to ten?
Doc
Doc
Live oak fla
I’m too small anyway …:)
Zeroedin
Matt
USA
Quick follow up question: I have the harness/clip free but there’s still no slack in the wiring to pull the harness to the hole. Do I need to remove this second clip through the sheet metal (2nd pic)…..or will that put me into “embarrassing trip to the dealer” territory? Thanks!
Crap, sorry….the pics rotated.
Danager
Dan
Alberta
2019 Edge
Manager
I just pulled at that point. Maybe the harness was doubled back and taped to itself? Cannot remember for sure.
