I am sorry to hear of your troubles.I do know that disconnecting the batter clears all adaptive learning tables.
Had never heard of a battery desulfator. Very interesting.I am sorry to hear of your troubles.
These modern autos are too complicated for their own good! The old rules no longer apply, and our new autos are much more fragile than our largely mechanical cars of the past. I've purchased two items that I think may help me (and maybe others) avoid the pitfalls that I am seeing here.
About 10 years ago I purchased a BatteryMINDer Model OBD-12 Desulfator for 2 of my vehicles. It is a simple to hook up device that breaks up the sulfur crystals on the lead battery plates whenever your engine is running. Since installing, my batteries last 3x longer than my neighbors. I got 10 years out of my last two batteries in both vehicles they were installed in.
I have just ordered another one for my 2020 Ranger. Prices have gone up since then (was $35) and the best price I could find was at an RV shop for $82 delivered to the door. This website is a little tricky and has a link to click to get the lower price of ~$65 + tax + shipping instead of the price listed at ~$79.
The second item was purchased quite a while back when I bought the truck. It is a small 12 volt adapter that is designed to keep your auto's computer settings when changing batteries. This means you must change the battery before a catastrophic battery failure occurs. You simply plug the device into a 12 volt port and plug it into a 110v wall outlet. It keeps power to your systems while you switch out your battery. I bought it on a whim, and thought I'd never need it. I now need to find it and keep it in my 2020 Ranger. Here is a similar device available from Amazon
My other autos are all old enough (2005, 2003, and 1993) not to need such nonsense as Item #2.
Yeah curious how this would connect. Maybe he’s got a pic? I’m used to a positive and negative terminal with nothing else attached. When I open the hood on this truck and looked at the battery I felt dump.Had never heard of a battery desulfator. Very interesting.
@TJC Would you connect this directly to the battery post or before the BCM. Do you know anything about the Noco Genius5?
I will be connecting mine to the posts ( I will not be disconnecting the battery, just taking off the nut). And yes, it as simple as that. The pigtail is used when you wish to charge the battery through the desulfator. Simply plug your charger into the pigtail, and it will charge and desulfate at the same time. The same is true if you connect to the + battery post and to the nut before the BCM on the negative terminal.. The desulfator goes to work when it sees a charging voltage, be from the alternator or an external charger.Had never heard of a battery desulfator. Very interesting.
Here is a picture of the BM desulfator installed in my 2005 Ranger. It is sitting on the antilock brake module next to the battery. Nothing more than Velcro holding it in place. Been there for a very long time 10-15 years. I've lost track of when I purchased it. I just put battery #3 in the truck 3 months ago. So 2 batteries replaced in 17 years, and the first one went a few years without the desulfator installed.Yeah curious how this would connect. Maybe he’s got a pic? I’m used to a positive and negative terminal with nothing else attached. When I open the hood on this truck and looked at the battery I felt dump.
It is worth a try. I certainly would do it... but what do I know?I don't know if this will help, but I am thinking that the dealer, possibly cleared the adaptive tables, but did not perform it correctly or just needs redone again.
Adaptive Learning Drive Cycle
Programming
NOTE: Perform the adaptive learning drive cycle on a level road surface.
- Using the scan tool, clear the DTCs (Diagnostic Trouble Codes) and Transmission Adaptive Tables.
- Drive the vehicle until the engine and transmission reach normal operating temperature.
- Accelerate from a stop with light throttle (15%) ensuring that upshifts 1st through 8th occur at engine speeds between 1300-1600 rpm.
- Continue to accelerate (may apply slightly more throttle after 7-8 upshift at 32-38 mph (51-61 km/h) until you achieve 55 mph (88 km/h) and the 8-9 and 9-10 shifts complete.
- Brake very gently to a complete stop and hold foot on brake for five (5) seconds.
- Shift the transmission to Neutral. Wait 1 second.
- Shift the transmission to Reverse. Wait 2 seconds.
- Shift the transmission to Drive. Wait 2 seconds.
- Repeat Steps 3 through 9 six additional times.
Insane right!Did your truck get struck by lighting in the middle of the night?
I believe that Ford pushed the envelope a little too far in an effort to meet Fed CAFE standards.Why is all this happening? Doesn't Ford test its products beforehand any more?
Great. Can't wait for the government-approved dishwashers to hit the scene.I believe that Ford pushed the envelope a little too far in an effort to meet Fed CAFE standards.
They (the Feds) are focusing on home appliances now.
I faced that choice...went with a new trans for couple of reasons...one, a rebuild will cost almost as much...you will not be saving much...two, you're building on a potentially weaken potentially damaged frame work...if done through Ford, either will have a 3 year unlimited warranty...I was lucky they had a new unit in stock so that made my decision slightly easier...a rebuild will take a whole lot of time...UPDATE:
So Ford called me today and informed me that they will be rebuilding the transmission. That's pretty much all the information I have as it hasn't been torn apart yet.
Should I push for a new trans or allow them to rebuild it?
