Upper Control Arms for Cast Iron Spindles
jstokello
Jack
San Diego, CA
2020 Ford Ranger XL STX 4x4
Supply Chain
Hello,
First time posting to this forum. I've found a lot of useful information in the short time I've been here, so thank you for that! I recently purchased some grimm racing uniball upper control arms for my 2020 ranger. Come to find out they don't fit rangers with cast iron spindles. After doing some research it appears no company makes UCA's for cast irons spindles on the 2019+ Ford Rangers. I was wondering if anyone on here knows of a company that makes UCA's for cast iron spindles or if a company is working on it? I contacted Stage 3 where I bought them, asking if they had any info. They responded saying they didn't know of any in the works.
MTBranger
Stefan
Austin, TX
2020 Ranger XLT FX4, 1994 Miata K-swap
Design Engineer/ Racecars
I bought Grimm Off road arms a few weeks ago not realizing they changed spindles either. I took measurements this weekend and sent it to Grimm so they could make the taper adapter for steel arms based off the stock ball joint and their design ( I'm a mech engineer, used to be in auto/racing industry). They never got back to me this week.
jstokello
jstokello
Jack
San Diego, CA
Supply Chain
Hopefully they are working on something based off your measurements, or already have something in the works. I emailed grimm to see if they had a different stud that would work, but haven't heard anything back. I installed mine and didn't realize the stud was the wrong size until I accidentally threaded the nut past the threads on the stud. It stripped out the nut and I had to cut it to remove it. I'm just using the stock UCA's for now.
Stephen
Stephen
Seattle, WA
2019 Ranger Lariat FX4
Logistics
I think I remember APG had a cast or aluminum spindle option, and they still have photos of the UCA on a cast spindle on their website.
https://automotiveperformancegroup....l-billet-upper-control-arms-with-heim-joints/
I just got my Radflo's last week, and am shopping for a UCA as well. However I have the aluminum spindle, and it appears only select builds in '20 had cast spindles. There are a couple threads on the forum for reference
fORdEGON
Ryan
Grants Pass, Oregon
2020 Ford Ranger SuperCab Lariat FX4
Excavation Contractor
I have the same Issue. New front coil overs just sitting until I can figure out the UCAs. I spoke with APG about their products and they do have an option for their billet UCA specifically for the cast spindles. They are pricey, use uni balls, and have adjustable heims. I was looking to get away from the uni ball set ups and go with the delta joint or sealed ball joint because of road salt/corrosion concerns in the winter but I don't see any options for the cast steel spindles.
Icon said they have extra washers included with their UCA to "take up the extra slack" when installing on the cast spindles but I think the actual taper might be different. I have another thread about this and no one has confirmed that they have installed Icons arms with the steel spindles.
jstokello
jstokello
Jack
San Diego, CA
Supply Chain
Yeah I'd like to avoid spending $1,300 dollars on uppers, especially when I only have fox 2.0's. Maybe I'll bite the bullet and try the Icon tubular with the delta joint, and just use the washers. I like the idea of not having the exposed uni ball anyway. First, I need to get replacement studs for my Grimm uppers and sell those.
Does anyone know if Ford will continue producing the ranger with cast spindles? I have to imagine companies will need to start making uppers for them at some point if that is the case.
avi8tornx211
Southern California
2020 Ford Ranger
APG is the answer. During my build they found this out and had to machine it inhouse. Took a few extra days; but, in the end glad i went with them. Excellent service and have continued to help out when i need it. Getting the new HD leaf springs installed in a few weeks when my rack gets back from powder coating.
Just be sure to call and specify so you don't order online with the wrong ones.
Or just go all out! The HD tie rods are beefy! ?
https://automotiveperformancegroup.com/product/apg-midrunner-suspension-package/
Living The Dream
Off topic, but what roof rack is that?
Looks great!
Back on topic, does anyone know if they switched back to aluminum?
Just looked on Stage3 and all of their aftermarket UCAs now have a bold Aluminum Spindles Only disclaimer.
jstokello
jstokello
Jack
San Diego, CA
Supply Chain
Quick update, I heard back from Grimm and there appears to be nothing in the works right now. However, Chris at Grimm got in contact with Stage 3 where I bought the UCA's from, and they were able to get me a refund. Stoked on the quick responses from both companies.
jstokello
jstokello
Jack
San Diego, CA
Supply Chain
Side note sweet truck, and looks like you're at San O haha.
fORdEGON
Ryan
Grants Pass, Oregon
Does this confirm that the taper is actually different for the cast steel spindles? Or is the angle of the taper still the same, but just the depth is less on the steel spindles?
jstokello
jstokello
Jack
San Diego, CA
Supply Chain
Stage 3 emailed me and they confirmed that the taper angle is different. They responded "At first we thought it just a spacer issues but a couple days ago Icon confirmed the taper angle is difference also.".
Turbofish
Hunter
Oklahoma
2020 Ford Ranger XLT FX4
Construction Manager
Seems like a really good opportunity for someone to come in and offer an UCA in the $800 price range. I was super interested in the delta joint but at this point I’d settle for something else.
fORdEGON
Ryan
Grants Pass, Oregon
BDS also confirmed with me today that they don't have an offering for the steel spindles either. APG or bust for the time being.
avi8tornx211
Southern California
2020 Ford Ranger
https://www.kchilites.com/kc-m-rack...crew-50-gravity-led-pro6-roof-rack-92244.html
They don't really sell it how i originally bought it... With the curved light bar and side lights) also out of stock for some time. Be aware: from what i hear they are known to send out wrong parts. I was going to put it in myself but with my better judgement and lack of time had APG do it. You have to remove A+B pillars, seatbelts, drop the headliner and avoid puncturing the side curtain airbags... Use rivet nuts or something like that which you need to know how to use. Not sure how to fully explain it's a um 81tch! And it cost a lot of money to install (correctly). Good thing i did because they sent the wrong size rack which would of confused the hell out of me and had to send pictures, proof, etc which is annoying to have them send the right ???.
I love it! Would i do it again, maybe... Love that it offers a ton of light!!! And since it was put together well it's solid! Prinsu makes a cool rack but not for the ranger, yet...
Ok maybe i would have gone with a different MOD for that price. Another picture of the inside setup.
