Underhood lights
ter240
2022 Ranger Lariat, Tremor
Self Employed
Installed some lights under the hood of my 22 Tremor. Started by removing the insulation panel to expose the underside of the hood. Two of the holes that the plastic rivets go into are perfect for mounting the lights. I used these lights.
https://www.kchilites.com/cyclone-v2-cyclone-v2-led-single-light.html?attr_pim_lenscolor=5730
The wiring was straight forward. Simple harness with a Y for the power and ground. Since the lights have bullet connections I used motorcycle 2 into 1 connectors to run to the Tremor aux switch wires.
https://www.amazon.com/Motorcycle-Bullet-Connectors-Covers-Terminals
The results are just what I hoped, lots of light on both sides of the engine bay. Just what Ford should have done.
Very bright! I DIY as well...
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
Too bad strobes consume so much electricity for when the hood is closed/truck is off to keep the mice out.
FunInTheSun
South Florida
Engineer (Semi-Retired)
Excellent idea. Masterful execution. Great results.
Bravo.
BS67
Brian
Nebraska
2022 Ranger XLT
They look great!
P-38Ranger
San Diego
2022 Ranger Lariat
How hot do they get? Was thinking of having a portable kid of set up. Of course since the hood is aluminium, I can’t use magnetic mount.
ter240
ter240
Self Employed
The lights are rated for under hood use by KC. I drove the truck most of yesterday and checked them when I got home. The lights were warm but not so hot that I couldn't keep my hand on them. Definitely something to watch.
DaveT
Scottsdale, AZ
2023 XLT Ranger Tremor
Here are the one's I installed, powered 100% of the time and fused and switched individually. They are panel LED's and very bright, work great.
PS Note engine cover :)
If they are powered 100% of the time, what happens when you turn off the engine? Do they just drain the battery?
JesseS
Jesse
NorCal (Roseville)
Hmmm? Did you not read the part about 'switched individually.'
DaveT
Scottsdale, AZ
Yes I did read that, and was wondering how there could be power 100% of the time when a switch was turned off.
