Ughhhh! Transmission Puked Fluid AGAIN!
Glocker
Boca Raton
Back in February 2025, I posted about an experience coming home from the beach on an hour drive home on the highway, and the transmission seeming to wig out, bang hard, and there being a smell of hot transmission fluid. When I got out of the truck, just off the interstate, I found there was transmission fluid all over.
I had a service done on the truck some time before that, but hadn't really driven it that much, and there was a belief that the pan may have been overfilled. The dealership said they believe it had "just burped" and the fluid levels were looking okay.
Fast forward to this morning! I had to get up early and take the wife 30 minutes down the road to the airport, on I-95. No issues. I took the turnpike back north to the house, and when I went to go pass someone, accelerating from 80 to 85, it felt like the truck was hitting a rev limiter and retarding ignition. It just felt like it didn't want to go.
I got to the house, and smelled hot transmission fluid. Ughhhh.
Once it was daylight, I went back out to the truck and there is fluid all over under there. Mostly under the transmission cross member, but also around the pan, and you can see where it has just blow all under the truck, starting from the sway bar back. There are also a couple of drips on the ground.
Damn. I don't know what to do next. This is awesome - my extended warranty ended this past May!!!!!! HAHAHAHAHAH! Of course!
RangerBill
I think that it was still overfilled and is only venting the fluid when you do long drives and get the transmission temperature high. If it is overfilled, it will foam when hot and vent. The foaming fluid will also cause the seeming lack of power that you experienced.
Ron
Mclean Texas
2021 Ford Ranger 4 wheel drive, 2012 f150 4 wheel drive
Farm and Ranch, retired HVAC/REF.,Electrician, Electronics service
You might check to see if the vent is plugged. Sometimes little bee's will crawl in and build a dirt nest in it. I saw a video where a shop had replaced a transmission pan gasket twice that was leaking. Looked at the vent and it was plugged by dirt.
Stevedbvik1
2022 Ranger Tremor XLT
If dealer didn’t do it right the first time what makes you think they got it right the second time? I know there’s some trust involved but trust requires verification
OCL
Mission Viejo, California
2021 Ford Ranger Tremor
You need to address this YESTERDAY. If it were overfilled it will indeed "burp" the bubbles out the vent hole along with fluids. Those bubbles that are created when the excess fluid is whipped around like your Cafe Latte drink. When those bubbles enter the circuits inside your transmission you get that slipping (you apply power when in gear and engine revs but no acceleration). Don't keep driving it and hope it just keeps burping until the fluid level is right, which the dumb-ass dealership alluded to "it just burped" comment. flush the fluid and replace with correct amount of fluid. Who replaced your fluid? Idiots.
This may or may not apply to 5th Gen Rangers but, the correct way to fill transmission fluid is to stop about a quart short of the book value. Start the engine and warm it all up. Then with engine running, cycle through all the gears staying on each for a few seconds. Then go back and check fluid level. Fill to correct level SLOWLY, and repeating the checks over and over until fluid level is correct.
TJC
Check it using the cold method if you have installed the MBS Dipstick (FitzStick). The cold method is the simplest way to do so.
Let your truck sit level over night, at least 8 hours, start it, run from Park to Sport and back at 5 second intervals, then immediately check the dipstick. Don't wait... check it immediately.
It should just show on the tip of the dipstick at 1/8" - 1/4". You're pushing the upper limit at anything above 1/4".
Tested to be accurate at 215F with fluid level on the diamond before 4 & 5. I ran the test at 75F ambient Air temp, Fluid was at 77.4F. Based on fluid temp expansion rates, you should be good from 65F - 85F ambient air temps.
ctechbob
Shawn
2020 Ranger XL/FX2/STX
Adult Daycare
I used your chart for the basis of checking the fluid in my 10R80MHT and it appears to be working just great!!
(The MHT (Hybrid) has to be between 4 and 3). Not sure why, it is the same stick as the Ranger had, but the 10R80MHT will go in to thermal runaway just like a normal 10R80, I can confirm that first hand.
TJC
I'm happy the data was useful for you. So the measurement is the same and the numbers adjusted lower on the stick? Or you extrapoiated?
ctechbob
Shawn
Adult Daycare
Stick is the same. They just call for a higher level of fluid in the Hybrid trans. Not entirely sure why, since you would think that you'd run into runaway problems the same as any other 10R, but that doesn't seem to be the case.
Rinn69
N. Central Iowa
Retired USAF MSgt
@Glocker Have you seen this from Beefcake Racing ? They mention using it on F-150's and Mustangs, no reason it shouldn't work on a Ranger....and another mod to do 😛 👍👍
TJC
The problem I see with the device is that it masks the issue. It stops the overflow, but does not address the foaming of the fluid which caused the overflow. And that is the real issue, you have cavitation, and the fluid no longer gets where it needs to be, and what little does simply heats up dramatically from the lack of fluid protecting the surface areas of all those moving parts.... clutches, clutch plates, etc.
it's just an aerated mess. Much like what happens when you overfill engine oil. Simple lack of lubrication.
