Rickfar
- First Name
- Rick
- Joined
- Jan 3, 2020
- Threads
- 12
- Messages
- 146
- Reaction score
- 154
- Location
- Central Pa. Harrisburg/Enola 17025
- Vehicle(s)
- 2019 supercrew sport
I just purchased the latest version of the kompact And the orientation when you install it does not matter with the new version. With the older version it has to be orientated in the correct position. If you call Richard at Turbo smart he can give you a wealth of information. And yes that O ring can be a bugger to get around the valve and stay there.I have one installed and you shouldn't hear anything while on the gas at low boost. The main thing I can think of is making sure you didn't forget to install the o-ring at the base or that the o-ring didn't fall out of its groove when installed. I used a little grease on the ring to make sure it sealed.
The only other thing that could be wrong is if you forgot to plug it in or the connection isn't correct. If that's the case, the boost may just leak out the recirculation tube and you'd hear it from the airbox?
