TSB: SSM 48026 - 2019 Ranger - SecuriCode Keyless-Entry Keypad - Inoperative Keyless Entry Key Pad
VAMike
2019 Ranger Lariat SuperCab
Has this problem (?) been rectified on the 2020 models???
It was a bad batch of parts, it would be nice to think they stopped installing those months ago when they identified the problem.
menright58
Mike Enright
Harvest Al
Some 2019 Rangers built with SecuriCode keyless-entry keypad, may experience an inoperative keypad. Press any button. If the keypad illuminates, the battery is operating normally. If not, replace the keypad. Refer to the PTS Workshop Tab drop down menu for installation instructions. Mouse over the Workshop tab > Accessory Installation > Electrical > Wireless RF Key Pad Instructions. As noted in Step 2, for removal use fishing string to remove the keypad to prevent paint damage. Do not attempt to replace the battery. This will break the seal and reduce the life of the keypad.
APPLICABLE VEHICLES
2019 TRUCK: FG P375N RANGER
Is the keypad attached by 2 sided tape? I really doubt I'll use it ever and it sure is ugly!
Cape Cruiser
Bret
Southern Delaware
retired mechanic
Mike it is held on with tape,but I have found it very useful although it looks like an after thought
JimH
Palm Coast, FL
See previous posts on this subject. i.e. take it off the door and put it on the inside of the fuel door..
Bproctor
Bruce
Hickory, NC
2019 Ford Ranger Lariat 2WD
NC National Guard
Makes me glad I removed mine. I didn't want it anyways and the dealers had no idea what they were saying when they told me it was hard-wired.
gfitzge2
Gregg
Louisville, Kentucky
Retired Electrician
Mine lasted just a little over a year before it started eating batteries. Hopefully this one lasts longer. No big deal.
Took about an hour for them to replace.
gfitzge2
Gregg
Retired Electrician
And they put back where I had moved it to. They didn't give me any grief about the relocation. :) ?
SICKQK
NY State
www.saddlebrookcontrols.com
2020 Ford Ranger XLT Crew Cab FX4
Automation Applications Engineer
Does anyone no whether or not this option when ordered with the truck is installed at the factory or at the dealership?
A dealer where I had my truck serviced (not where I purchased it) told me they don't come on the vehicles from the factory, that the dealer installs them. That's news to me and it resulted in an argument because the service writer said they wouldn't look at it because it is considered "aftermarket ".
Thanks!
tgRanger
NJ
I don’t “know” so I can’t say Yes or “No”. :giggle:
alcohenusa
Alan
CO
2020 Ranger Lariat 4x4
Thanks!
They are installed at the factory If ordered that way. However, they are also available as an add-on accessory.
SICKQK
NY State
Thanks. Mine is listed on the window sticker and build sheet.
Service writer first told me it was added at a shop my dealer used......then when I showed him the window sticker he said well then the dealer installed it.
gfitzge2
Gregg
Retired Electrician
It doesn't matter, factory or dealer. If its on the window sticker, it is covered. Many of these were defective. I think there was some sort of service bulletin. This dealer replaced mine no questions asked. I had even moved it from its original location on the door to the B pillar. He replaced it to the new location.
Cape Cruiser
Bret
Southern Delaware
retired mechanic
Gregg, is the key pad staying tight to the vinyl on the door pillar ? I like it in that position. Bret
Cape Cruiser
Bret
Southern Delaware
retired mechanic
I know there are a few members here with 2 Rangers and also a few Ford Techs. Do any of you know if I program the key pads on my 19&20 with the same code will they interfere with each other ? Thanks Bret
gfitzge2
Gregg
Retired Electrician
Yes it is staying put no problem. I put it on the back door so it wouldn't would take as much shock, but I don't think it would be a problem on the front door.
