Tremor Upfitter switches
RangerTX
Illinois
2021 Ranger Lariat FX4
Ok - I have a weird one for you all.
My wife has the Tremor. She will never use the dash mounted switches that come with the Tremor.
I have the FX4 and desperatley want the switches. I was hoping that the wiring harness was in the FX4 and that all I would have to do is plug/play. It does not appear that is the case. I even peeled back my dash tray and didnt see any connectors in there.
Seems more than its worth to try to swap that... unless I am missing something????
halligan1201
Byron, IL
2020 Ranger
Emergency Management
The wiring isn't there. It runs from the dedicated little fuse box that they tape into the Tremor. If you don't have the box taped in there, you don't have the wiring for the switches..
RangerTX
RangerTX
Illinois
Yea, I found that box. But for the life of me I couldnt identify any corresponding harness in the FX4.
Dang!
AZ_Tremor
Angelito
Cave Creek AZ
2022 Ford Ranger XLT Tremor
Field engineer
Dang!
You could snag her box (no pun intended),
Switch box and run your own wires from the box to the battery…. You’ll need to add fuseable links at the battery end and maybe a relay but you could make it work…
It shouldn’t be that difficult… you don’t necessarily need the Aux box that comes with the tremor but you could also make that box work if you know anything about electronics…
Mine is in on the shop now because the aux box is not working from the factory when I was testing the system before I dropped it off at the shop I hard wired my lights right to the switches to make sure they weren’t faulty
hell
Pittsburgh
2022 Ford Ranger XLT FX4 Crew
Danager
Dan
Alberta
2019 Edge
Manager
For the cost and hassle, I would really consider one of the aftermarket wireless systems. These also tend to be more configurable. Don’t get me wrong, I use and like the switches in my Tremor.
Shaneb72
Shane
McKinney Texas
2021 Ford Ranger XLT FX4 302A Oxford White
Registered nurse Workers Comp Case Manager
I know this was an older question but I attached the wiring diagram and replacement procedure for the Tremor Aux switches, I hope it helps someone.
veedubtuner
Morgan
Tulsa, OK
2023 CG XLT Scab FX4 Ranger/2004 VW R32 (FOR SALE)
VW Parts slinger
