Tremor 2” level from ford ranger lifts.
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
What happened that it took you so long?
When I did the level on my Tremor it took about 2 1/2 hours and that included running to the part store for a socket to fit the axle nut and a soda break between sides.
It look me forever to figure out how to get the ball joint off and tie rod off. Once I got the courage to smack it just right with a hammer everything went fine.
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
Got my alignment redone to try and reduce the camber values
SSingh1975
Elk Grove, CA
['21 Ford Ranger XLT (Tremor) , BMW IX Electric
Any pictures of the truck (before and after)? I ordered the same 1" kit and waiting for my local shop for an open schedule (they only open mon-friday). cheers
Installed my 1” level kit on my xlttremor today. I’ll list the steps in the order I took . This way seemed to be pretty easy and safe in my opinion.
EAC83
Erin
Pope, MS
2021 Ford Ranger XLT Tremor
A couple of before and after pics… I went with the 1” because I tow often. My gas mileage average dropped at minimum 1 mpg after install. Overall I’m very happy with the look. It’s a little front high when towing my sxs and 12 ft trailer but not too bad. Remember to adjust your headlights or you’ll get bright lighted often.
SSingh1975
Elk Grove, CA
^ that looks perfect. I'm going forward with the 1" as well. Exactly the look I'm looking for...little bit of rake but still a better stance than stock. thanks for the pics bud!
amick1995
Alex
CO
2021 Ranger Lariat Trenor
I installed the 1" and I am level.
2" is too high.
When you add a steel bumper and winch 2” is perfect IMO. Although I’m going to be going with king extended travel coil overs since I got in on the UCA group buy
SSingh1975
Elk Grove, CA
Finally got the 1" spacers installed today. Love the stance. Still some rake but I added 2 inches of fender space in the front (I had measured before/after).
Definitely can "feel" it when I picked up the truck from the shop this afternoon. I wish truck came with this stance from factory as IMO, 1" lift is perfect (even for towing).
awd.nv
Anthony
Las Vegas, NV
'21 Ranger XLT Tremor
Computers
I just towed this past weekend, did the 1" level Monday and will be towing again this weekend. Curious to see how different it feels. Going to factor some extra time to adjust my WDH if necessary.
Tremot Trent
Trent
Kansas
2022 Tremor
Driver
Know it’s about preference, dealer, near me has a performance/build specialty on Ford lineup. Actually had 2 Tremors, 1 with 1” level, 1 with 2” level heavy bumper/warn winch. Side by side both same height at top of wheel well and level along bottom. Also 2” on stock 4X. After seeing. I put the 1”. Figure a lot of look is due to body lines, so again preference
hookem57
Don
Fort Worth
2021 Ranger Tremor
Driver
Just wanted to thank Robert and anyone else who works with ford ranger lifts. Ordered my 2” tremor level from them last week, shipping was 2-3 days, packaged nicely.
Today was my saturday to work and took the time to install the kit today. Having a lift makes it a breeze and after some slight prying, the strut with the puck on top goes in. The instructions included with the kit are pretty accurate for the most part, the only thing i did different was completely separate the cv axle from the bearing to ensure i had ample room to pry the lower arm down to fit the strut in.
Aligned it after, the vehicle is so new that our hunter machine did not have the specs for the tremor so I used a 20 4x4 ranger as the vehicle and manually entered the specs for the various angles. Also adjusted headlamps down so im not that guy at night.
Happy with how it turned out and now just to wait for my tonneau cover and a few pigtails from Ford so i can install my bed lights and cover!
Attached is a before and after, before is in the stall, after is where i was adjusting lamps off of the shop door.
I've got the same lift kit. Drive a truck so have not had a chance to install. That's exactly what I'm after. Nice looking truck.
CATX
Will
2021 Ford Ranger TURBO
Interested in the 1” level. What is a reasonable price to pay to have someone install ?
