Transmission Fluid Fill
outdoorphotog
Ian
Healdsburg, CA
2019 Lincoln Navigator L
Limo Driver
I found the PID for my Scanguage II, I am going to get a longer glove and attempt to check my level tommorow.
outdoorphotog
Ian
Healdsburg, CA
Limo Driver
AFter all that, i checked the temp around 207F, it was right near the 4. SO all is well. What a pain in the ass to do.
landiscarrier
Landis
Pocono Mtns Pa
2025 Ranger Raptor
Sales
My son and I just changed all the fluids, my son is an A-Tech for GM. The transmission was definitely about 1.5 quarts low from the factory. Drained 5 (slightly more) put 6.5 back in to get it to between 4-5 on the dipstick….the dipstick that apparently a dipstick designed! Lol.
Bsqrd
Arizona
2020 Ford Ranger SuperCrew Lariat FX4
So has anyone compared what the dipstick reads while cold vs hot? Curious what the difference would be.
Dgc333
21 Ranger Lariat
There is a Ford techno you tube that says the difference between cold and hot is one number. So if you are between 4 & 5 hot it will be 5 & 6 cold.
Porpoise Hork
Bret
Houston
IT
Shouldn't the first time be during dealer prep?
One would think, but a a very large number of us discovered that the dealership's make ready departments couldn't even properly check the air pressure in the tires. There's no way those clowns would know how to properly check the transmission fluid level.
Dgc333
21 Ranger Lariat
The factory intends the tranny to not require routine servicing or they would have provided a conventional dipstick. I would bet a beer that checking the tranny fluid is not on the new car prep checklist.
Rapid Roy
Gary
Russellville
2002 Ranger FX4
Rapid Roy
Gary
Russellville
2002 Ranger FX4
That is very odd especially when trucks are coming out low on fluid. I wonder if I should take my new truck to an independent mechanic before accepting delivery
JasonTremor
2021 Ranger Tremor XLT
My understanding was that between 5-6 was full hot. 4-5 would technically be overfilled if I read it correctly. Sorry for the bad screen capture below as I captured in it from a YouTube video from a ford tech.
landiscarrier
Landis
Pocono Mtns Pa
2025 Ranger Raptor
Sales
We checked it while hot with a scan tool hooked up to it to monitor correct trans temp for accurate measurement.
JasonTremor
Interesting indeed. The screen grab I had was from a ford service manual supposedly. Now I wonder which is correct. Appreciate the screen capture!
