TOYO Open Country A/T III
mobilemike01
Tampa, FL
Ranger Lariat
I don’t have a ton of miles on them yet, but haven’t noticed any substantial road noise or weird handling. I live in FL so they have seen plenty of rain and wet roads and no issues there either.
No off-roading or mud yet, so I can’t speak on how well they would preform in those scenarios.
I love the look of these, especially over stock. These with the level and 1.5” spacers make the truck look “right”. Like they should come from the factory IMO.
SknyGny
Keith
Middletown, Ct
2019 Ford Ranger Lariat
No worries. Didn't take it badly. I certainly understand that the fuel mileage issue for the most part is a non-issue (particularly on the Jeep Forum), but I'm one of those curious guys that likes to see and try different things, hence why I went with the TOYOs this time around. Understandably, I expect some tires to be worse than others, but sometimes they will surprise you. I think one of the other factors is that different drivers encounter different situations, that is, tire type, tire pressure, vehicle lifts, weather, speed, traffic, etc. Can be difficult sometimes to try and account for it all.
Be safe, stay healthy everyone.
Bronco unveil tomorrow night!
Waiting for the bronco might have to trade in the Ranger LOL
CharChar
Atlanta, GA
2019 Ford Ranger XLT Fx4
DrPerez007
DrPerez007
Wisconsin/Florida
‘05 Jeep TJ & ‘19 JLU; ‘19 Ranger Lariat; '25 Durango; ‘26 Cad CT4 BW
Public Safety & Legal Consultant
Mobile Mike, what lift do you have on this and what size tires?
Hi CC,
Is 60 psi a manufacturer recommendation? Really seems quite high inflation.
CharChar
Atlanta, GA
Hi CC,
Load range E is 80psi max. I always ran my 3/4 ton at 75, but I figured since this truck is so much lighter 60 seemed more appropriate to avoid uneven tire wear.
Swingpure
Gary
McDougall, Ontario
2020 Ford Ranger XLT Sport
So, my experience is so far limited to driving home. But for what its worth...
I went with the E range, and can notice the stiffness. I actually prefer it, as i felt like the truck is a little to "hyper" up front. Tread depth is significantly more, which was my main reason for upgrading. But the road noise is substantially louder. Plenty of clearance on stock suspension.
I've had Cooper AT3's on 3 straight vehicles and have had great luck with them. These look a step more aggressive, which is why i chose them. Previously had BFBoodrich AT's, which are a substantial step down. Going turkey hunting next week, so i can report back with interstate + offroad impressions then.
How did you get white lettering on your tires. All of the other Toyo AT3 tires I have seen have been all black. Is it simply an option you ask for?
Your Tires look great. I now always choose Toyo for my winter tires.
CharChar
Atlanta, GA
When i ordered them, there was an option.
They have been so good. I still cant recommend them enough!
Swingpure
Gary
McDougall, Ontario
Great looking tire and truck!
You mention road noise was not a big issue for your tires. On another post on this thread, it was mention E rated tires are noisier than C rated tires. What rating are your tires?
Adventure Ranger
Saskatchewan, Canada
2020 Ford Ranger Lariate Crew Cab FX4 Sport
Heavy Equipment / Truck shop Foreman
I've have Toyo Open Country AT2 - AW tires on my truck since new. P265/70R17. Installed at the dealer before I took the truck. I have a 2.5" BDS lift in front and FOX 2.0 shocks in rear. Fuel economy was 25-27 Impg in summer, now that is cold I'm down to 22-24 Impg. Run tires at 32-34 psi. In Canada winter rated tires are LAW in the mountains from October 1st - April 30th. Toyo AT3 are not available in Canada yet.
The AT2 I have did "sing" quite a bit when new, that settled down after a few thousand kms.
They provide good grip on wet and dry, snow performance has been good so far as well. I drove over Rogers Pass through a blizzard, down to 40kms/hr due to visibility and the tires kept us firmly planted on the road. Happy with these, once worn out I'll probably change to the AT3 - they should be available in the Great White North in a few years !
Swingpure
Gary
McDougall, Ontario
I just got a reply back from Toyo Canada and the Open Country AT3 will be launched this March!
Swingpure
Gary
McDougall, Ontario
I really like this tire.
In doing my research on the size I would like, I noticed that the OWL tire, with the exact same specs as the BSW tire, is 3 lbs heavier per tire. They must use lead paint! ?
