Tire Size-Mixed results
Redman555
MIchael
Roseville, CA
2020 Ranger FX4- Lariat
So I seem to be getting mixed results on what tires will fit on what, so I wanted to get some input.
I have a 2020 Ranger Lariat FX4 that my leveling kit will be going on next week, it is 2.5".
I have seen a few people post that 275/65r18 are too big for a 2.5, and that it rubs as well as gets dangerously close to the steering components...but others have said they're fine.
I am currently running these factory wheels: https://www.autorimshop.com/18-oem-...8QZi1RPblxlqoxgCL2Jcew0eYXBDSpExoCZI0QAvD_BwE
and am trying to figure out if I need to stick with 265s or if I can fit 275s without ANY RUBBING or any adjustment to the crash bar.
Can anyone help me? Please and thank you!
Redman555
MIchael
Roseville, CA
There's a ton of info in this thread about all different tire sizes.
https://www.ranger5g.com/forum/threads/tire-size-fitment-master-thread.1680/
Also you can compare sizes using this tires chart. That way if someone has a 17" that doesn't rub you can input your 18" and see if/what the difference is.
https://tiresize.com/comparison/
I have 265/70/17 and had no rubbing when I had my 2.5" level kit. I've since switched to a full coiliover and still no rubbing.
Well, I have 265s now, that is what were on them when I got it, more curious about getting 275s on it.
Brett Fields
Brett
Brooklyn
Paramedic
Wheel offset is also a factor. I went from the black 18's to 285 70 17 with Fuel Shock wheels with a +25 offset and Fox 2.0's. Hi clearance crash bars.
rydfree
Benny
Maintenance
Falken WildPeak 275/65R18 are fine on my 2020 Lariat FX4 with a 2.5" level kit.
Honestly different tires even in the same size may act differently in certain conditions because of sidewall construction etc . I was concerned about tolerance between suspension components, but these have worked out fine even aired down some or when the psi was somewhat high as I was testing how it affected the ride. I ended up at 32psi cold and on very cold mornings like we had here a week or so ago they were running in the 28psi range with no issues.
CWO4
Michael
Hubert, NC
23 Rager FX4
Retired Marine
With your set up what kind of tire tread, not sidewall, poke do you have. I have some 17" 8.5 wide +25 mm rims with Fox 2.0 stage 1, Icon UCA, hi cleaner crash bars that I am putting on a 23 FX4 and having problems deciding between 285's and 275's, 70R17.
Blmpkn
Maine
2010 ranger
With your set up what kind of tire tread, not sidewall, poke do you have. I have some 17" 8.5 wide +25 mm rims with Fox 2.0 stage 1, Icon UPC, hi cleaner crash bars that I am putting on a 23 FX4 and having problems deciding between 285's and 275's, 70R17.
275s on 9" wide +18s. Tread is just barely underneath the fender.
Brett Fields
Brett
Brooklyn
Paramedic
I don't have a good image at the moment, but I guess I gotta say 13mm more than blmpkn? I definitely get splatter down the sides now.
Really considering flares.
Brett Fields
Brett
Brooklyn
Paramedic
If I had it to do again, I'd likely go 275. My off roading is recreational only. The 275s would be better for my mostly pavement life.
I would never trade my KO2's though.
CWO4
Michael
Hubert, NC
23 Rager FX4
Retired Marine
Thank You, yea I was thinking same but went 285 to do off road trips with my son. I also was looking at flares, the OEM Bushwackers or RTR.
CWO4
Michael
Hubert, NC
23 Rager FX4
Retired Marine
After reading your help and staying up all night I changed my order to 275 70R17, thank you
Brett Fields
Brett
Brooklyn
Paramedic
Geez.... Now it's gonna be MY fault! ?
I know what your going through. Problem is... you can never be 100% confident in your choice unless you've done both things. These tires are too expensive to play around with though. They're a significant investment. I did 5 wheels & 5 tires.
Brett Fields
Brett
Brooklyn
Paramedic
Ah.... but to color match or not to color match. That is the question!
