The warden wants me to double check!
Ranger X3
Matthew
Sedona AZ
2019 Ranger Supercab Lariat FX4
Hi all,
Tire shopping is in the near future and I told the warden that I was looking into the Tremor wheels so I can get a little more poke out of the tires. She wants me to check with the "Ranger Gods" to make sure they will fit. 2019 SCab with the FFP leveling kit, looking to move to 265/70/R17 from 265/60/R18.
Thanks in advance.
Matt
Just understand that there is a SMALL(in large print) Difference between the Tremor and "Raptor" wheels for the Ranger. The difference is the offset. The Tremmor Wheels do stick out a little more(cant remember how much) but not to where they wont fit. Overall you should be fine
Ronbo
Ron
FL, CT, TX
2019 Ford Ranger XLT FX4+
Hi all,
Thanks in advance.
Matt
I did just that on my 2019 Screw. Tremor wheels with 265/70/17 tires. I have the RC leveling kit. The tires poke out probably a half inch or so with the Tremor wheels. They have a +42 offset versus the +55 offset on the stock sport wheels. No rubbing or other issues except a little loss on the MPG’s because of the heavier tires.
yep no worries they will fit and look great
Ranger54
Ben
Northwest Arkansas
2020 Ford Ranger Lariat FX4
Service advisor
I mean… 285/70r17’s fit with no issues with tremor wheels, 1.5” spacers, RC 2.5” level. My old setup:
Ranger54
Ben
Northwest Arkansas
Service advisor
265/70r17 fit bone stock with 1” wheel spacers as well.
NotBudule
XLT
That grille though ... damn...
Those wheels will look sharp on your Lariat. Some of the Tremor owners have reported a bit of rubbing at full lock. You might need to loosen the bolts on the crash bars (15mm IIRC). There should be some play that will allow you to push on the bars to angle them away from the wheel and give you a bit more clearance. Tighten it all back up and you should be fine.
Post some pics when you’re done. You already have a rare truck - not many Lariat Scabs out there and not available in Canada (only Screws in Lariat trim here).
Ranger X3
Ranger X3
Matthew
Sedona AZ
Thanks everyone for the feedback!
