That was WAY Easier! 1" Tremor Level.
Copperhead_Tremor
DK
Louisville KY
2023 Tremor Ranger
Dispatcher
So Theres 3 different ways to install a leveling kit on these Rangers.....
I researched each one and found dropping the lower control arm WAY Easier than some of the other horror stories. (Separated CV joints, Pushing/prying on control arms etc.)
Checkout the video I did on it:
TXRangerTim
Tim
TX
2021 XLT Tremor
I like the standard Rokbloks better than the XL they recommend. I might be adding those soon. :thumbsup:
Joeiconic
2021 Ranger XLT
Great looking truck. With those beefy tires, I think you will wish you had the larger mud flaps. I wonder if you could get the XL size and trim off that little protrusion to make it a uniform curve? Maybe with a sander?
OneMore
Walter
Bay Area, NorCal, CA
2022 Ranger Lariat Tremor
Dk, thanks for the great video.
I also have a Ranger Tremor. Need to install my 1" level and seeing your lower A arm removal solution tells me this is the simple way to get this done.
I will also purchase the standard version of RokBlokz mud flaps. Stock tires on my truck, and after seeing your install of the standard size they will work for me. I too don't want the flaps sticking out to far.
Showing the additional lighting in operation was helpful also.
Something else for me to spend my money on.
Mighty Little Blue
Wisconsin Rapids, WI / Philippines
2021 Velocity Blue Supercab FX4
Printer/Retired
Agree 100% so much easier to go from the bottom undoing the LCA. That is the way I did mine also. There is a video of it on you tube from a member here Josh Mills that goes into a little more detail. It is really easy to do it this way.
