1" Tremor level with my Bilstein 5100s
TORQUERULES
US
Ranger
When I installed the 5100s I left the adjustment stock so I could theoretically preserve ride and keep suspension travel. I saw the 1" Tremor level was out and decided to give that a try to level a little, but not have the high in the front look that I see with a lot of 2.5" level kits. The install went great and using my home camber gauge and toe gauge I was able to get things where I wanted. My camber gauge only goes in .5 degree increments, so at first I had .5 degrees negative dialed in, but once the suspension settled I have 1 degree negative. Toe of course had to be readjusted, but I did not reset the camber as it drives very nicely this way. I have not had time to check the caster (which may cause me fits and have to start all over again). Like I said, it drives and handles very nicely now, better than when I bought it, and although the camber is noticeable, I might leave it alone. It kind of has that F150 Raptor look as they have a little more negative camber than a regular F150. What do you guys think? Anyone else running 1 degree negative? I plan to rotate my tires every 6K miles, so I really do not see it as being too much of an issue.
jflogerzi
Moreno Valley, CA
I would just get it aligned IMO. Anytime you mess with Front suspension its ideal to do this.
Ranger_Pawl
Huron Twp., Mi
2020 Ranger XLT Supercab
- Draftsman
Hi Matt. My 2020 FX4 with the Ford Fox 2" level appears to have some positive camber when I look at it from the front. Sure enough, I noticed this weekend that all 4 of my tires (4 rotations in 23k miles) appear to be wearing on the outside. I plan on getting it into the dealership to have the camber/alignment evaluated. Just wanted to let you know my tires were wearing unevenly with improper camber.
TORQUERULES
TORQUERULES
US
Ranger
I've had quite a bit of experience with alignment changes and wear, so I know the pitfalls of all that. Yea, that much positive is insane. Hope you get it figured out.
Kind of just wanted to see what everyone's experience was with some negative camber. You know, handling, ride, etc. Thanks for the feedback!
XLT and me
michael
NE Ohio
2019 xlt ranger 62 galaxie
Truck driver
usually a very small amount of out of spec camber doesn't affect driveability much. But it will accelerate tire wear, and possibly wheel bearing wear. You will probably have to rotate tires more frequently also. I would just spend the $100 to get it aligned dead on, just because how expensive tires are, it will probably save you money in the long term. Do you have any side view pictures of your truck with the 1" lift? That is all I would like to lift mine with the Eibachs i have, (not installed yet)hard to find pictures of trucks that don't have a 2"+ level.
TORQUERULES
TORQUERULES
US
Ranger
TORQUERULES
TORQUERULES
US
Ranger
After driving it more today I'm actually sitting at 0.5° negative and I think I'll leave that alone. It really handles and drives nice there.
Rp930
Denver
‘19 Ford Ranger Lariat,MB GLK250,’21 Shelby GT500
.5 should be no problem. Be sure the toe is correct.
TORQUERULES
TORQUERULES
US
Ranger
Just measured caster. Driver's side 3.5 degrees positive. Passenger slightly over 3.5 degrees positive.
XLT and me
michael
NE Ohio
Truck driver
Looks great, thanks for the picture. I have not seen a hot pepper red super cab, really like that combo.
TORQUERULES
TORQUERULES
US
Ranger
Thanks! It is exactly how I would have ordered one. Glad I found it.
Aonarch
Alec
North GA/ Montana
I confused about the "Tremor one inch level"
You bought a spacer level kit designed for the Tremor?
Fitzmotor
Gold Sponsor
Saugus
Retired from Honda Racing.
I run as close to zero camber as I can, I tend to edge wear the tires from hard cornering.
Negative camber does give a better cornering feel, but it tends to hunt on straight roads, especially if the road has rain grooves.
