VAMike
still probably the cable. my recommendation is always a really short one (like 6 inches). if that fixes the issue, you can either work on finding a long cable that works or use the short cable to connect the wireless adapter (what I did). android auto is trying to push a lot of data over that cable, stressing it much more than most low- or no- bandwidth applications, and cars are notorious for being electrically noisy. the longer the cable, the more likely it is to pull in interference from the environment, have crosstalk within the cable, have excessive voltage drop, etc. all of those issues can be prevented with shielded cable, properly twisted pairs, properly sized conductors, etc., but there's no real way to know whether a given cable was built well without cutting it open. a short cable makes it much more likely to pass a clean signal regardless of build quality.
one thing you can be sure of: the amount you pay for a cable has basically nothing to do with how well it's built
