SVC Leveling Collar
  • Thread starter Deleted member 773
  • Start date
  • Watchers 11
Rp930
Denver
Starting to look like a good direction to go.
IdriveG5
NC
Ranger FX4
Wondering has everybody been able to install these with a portable spring compressor, not taking off truck?
Rp930
Denver
It looks like it’s strut out to install to me.
PNW_Ranger87
Erik
Renton, WA
2019 Ranger XLT 4X4
Parts Specialist
Taking the strut out of the truck isn't the difficult part. Actually I'm not sure how you would be able to remove and replace springs on a strut without removing it from the vehicle.
IdriveG5
NC
Ranger FX4
Thanks! What I was thinking as well, but I have not pulled my wheel off to check space. Looks like on ranger not enough room for a portable spring compressor. Unlike on Raptor where people have put collars on without taking off vehicle.
MTB-BRUH
Tyler
Shingletown CA
2019 Ranger Base
Shop Manager
This goes underneath the spring, not on top of the assembly. You have to completely remove strut assembly. I’m loving my SVC leveling collars, I feel like the truck needed the front end firmed up, have put about 3000 miles on it with a decent amount of off-road abuse. Very happy
IdriveG5
NC
Ranger FX4
Nice looking stance! Yeah I knew they went underneath, but was not sure if you could install like the rpg collars. How the collars attaches to these struts now looking more closely appear different then on the Ford Raptors. If you check this link you can see why I was wondering can see around 1:40 starts doing on truck. Just trying to learn as much as possible, before I attempt anything!
T-Wrecks
Roberts, WI
19 XLT FX4 S Cab, FX4, 301A, Tow, Technology
What about just installing spacers? Can you drop the strut enough to install without removing them?
rooster
BOS
STX FX4 SuperCrew
nerd
Once the strut is disassembled as such does the factory perch pop off (i.e. press fit)? Asking for a friend.
SN13
2019 Ranger XL Oxford White
Have had mine for about 4K miles now. FX4. Including light offroading around the mountains of NC.
Zero issues and no creaking yet!
I put 8k miles on mine so far.
The ONLY issue is that it made my front camber a little positive and that made my outside tread wear faster than the inside.
Im in the process of getting the camber put more negative/neutral.
MTB-BRUH
Tyler
Shingletown CA
2019 Ranger Base
Shop Manager
You never got a alignment after install?
SN13
The truck rode perfectly straight.
The positive camber was hardly noticable.
Plus none of the quick-alignment guys have the "Ranger Spec" and I'm trying to find a real shop that will just adjust it manually without the "Spec" info crap.
Also it took 8k miles to really show up and it's not like it made the outside bald just that it wore a little more than the inside.
Hi Folks,
When you modify your suspension...there are no Specs from Ford that apply...your kit seller should provide this to you. If not, all bets are off...you are in uncharted territory.. This is why I made a recommendation on caster and the fellow responded.."you are recommending exceeding the Ford spec???...Yep...Ford Specs do not apply to modified vehicles..."
